make it do a test page, seen how to do that in the free to read manual
this always first. to prove printer even works at. self test. page
page 61 and more
show what to do, no PC needed at all.
How to use the solutions in this document
To resolve the issue, try each solution
in this document, and then use the steps in this section to print a
self-test report. This step determines if the product hardware functions
correctly. When you have resolved the issue, and the product
successfully prints a self-test report, there is no need to continue
troubleshooting.
Print a self-test page
Follow these steps to print a self-test report.
Load plain paper in the paper tray.
Press the Power button (
) to turn on the product.
Press and hold the Power button (
Press the Resume button (
) four times. The self-test page prints.
IMPORTANT
: Try to print a self-test report after every solution even if the solution resolves the issue.
Touch and hold app to move until it starts to jiggle.Drag app to bottom of screen placing with other apps ,scroll screen to home screen,take app from bottom and move to home screen.Apps can be moved to any screen as long as they jiggle.
Hi, you can print a configuration page from the C6180 by following these steps:
- Press the Setup button on the printer's operation panel - Using the down arrow button, scroll down until you see Network, then press OK. - Scroll down again until you see View Network Settings, then press OK. - Scroll down until you see Print Network Configuration Page, then press OK.
To view configuration page instructions and ways to view page counts on other printers, copiers, and fax machines, visit the How to Print Configuration Pages blog.
To determine what the problem is run a self test page. Push the "Setup" button then choose option 2 then option 5. This will print a Self test report page.
For more detailed information (assuming you did a standard install) go to "Start", choose "All Programs", choose your HP menu option, choose "OfficeJet All-In-One 7300 series", choose "Help". Once your in Help scroll down to "Maintain your HP All-In-One", open the sub-menu and choose "Clean the HP All-In-One". On the main help page sellect "Print a Self-test Report". This should tell you just about all you need. Good Luck!
You may clean the cartridge by following the steps given below:
1. Remove the cartridge or cartridges from the printer. 2. Get a damp paper towel. 3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds. 4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. 5. Next dab the cartridge on the towel to make sure that the ink is flowing. 6. Snap the cartridges back into the printer.
Next, I'd like you to attempt this printer self-test by following the steps given below:
1. Disconnect the power cord from the back of the printer.
2. Press and hold the button on the printer panel.
3. Reconnect the power cord and keep holding the button on the printer panel until the printer starts to pull paper.
4. The printer should now print a test page. Please note that the test is continuous. To stop the test, disconnect the power cord.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
If the printer was reset recently then you will not et the entire or exact page count till day, but you can still run a Print self test report and check for the information:
To Run:
On the front panel of the product, press Menu (or Setup) .
Press the Right Arrow until Print Reports displays, and then press Enter, Start, or OK .
Press the Right Arrow until Self-Test Report displays, and then press Enter, Start, or OK .
It will print a self test page and you will find the page count in thie page
