20 Most Recent HP Photosmart C6180 All-In-One InkJet Printer Questions & Answers
Contact HP for Care at 1-800-585-2494
HP Photosmart... | Answered on Dec 12, 2018
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
HP Photosmart... | Answered on Oct 13, 2018
Contact HP for Care at 1-800-585-2494.
HP Photosmart... | Answered on Oct 10, 2018
En anglais - c'est trop longtemps que je parle francais...
The code you mentioned sounds like an Ink System Failure code. My C6180 had the 0xc19a0035 Ink System Failure code, eventually the printer would power on and off every 15-20 seconds - continuously. Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers. acca299.jpg
HP Photosmart... | Answered on Aug 13, 2018
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
HP Photosmart... | Answered on Jun 28, 2018
Quickbooks has a print option where you can adjust how the checks print. I have always made a copy of the blank check and adjust the settings until it prints on the line. If you keep making adjustments you can get it to print almost
perfectly.
HP Photosmart... | Answered on Mar 19, 2018
Applicable error codes
This document applies to Ink System Failure error messages with any of the following codes:
0xC19A0001, 0xC19A0002, 0xC19A0003, 0xC19A0006, 0xC19A0008, 0xC19A0009, 0xC19A0013, 0xC19A0014, 0xC19A0015, 0xC19A0020, 0xC19A0021, 0xC19A0022, 0xC19A0023, 0xC19A0024, 0xC19A0025, 0xC19A0026, 0xC19A0027, 0xC19A0028, 0xC19A0030, 0xC19A0033, 0xC19A0034, 0xC19A0035, 0xC19A0036, 0xC19A0037, 0xc19A0040, 0xc19A0041, 0xc19A0042, 0xC19AC001, 0xC19AC002, 0xC19AC004, 0xC19AC008, 0xC19AC010, 0xC19AC020, 0xC19AC040, 0xC19AC063, 0xC19AC080, 0xC19AC0a5, 0xC19AC0c6, 0xC19AC0e7, 0xC19AC100, 0xC19AC129, 0xC19AC14a, 0xC19AC16b, 0xC19AC18c, 0xC19AC1ad, 0xC19AC1ce, 0xC19AC1ef, 0xC19AC200, 0xC19AC231, 0xC19AC252, 0xC19AC273, 0xC19AC294, 0xC19AC2b5, 0xC19AC2d6, 0xC19AC2f7, 0xC19AC318, 0xC19AC339, 0xC19AC35a, 0xC19AC37b, 0xC19AC39c, 0xC19AC3bd, 0xC19AC3de, 0xC19AC3ff, 0xC19AC400
HP Photosmart C6380 and others
Hi
There there to much to tell you what to do but I found a link for you to see it will tell you what to do just click on the link it will take you there.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01458034&lc=en&dlc=he&cc=il&lang=he&rule=6783&product=3655608
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
HP Photosmart... | Answered on Jan 26, 2018
Go here
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&tmp_task=solveCategory&lc=en&dlc=en&cc=us&site=null&lang=en&rule=11380&product=1153494&key=null
-You should have a number (fax number) for it in order to be able to receive incoming fax.
Good luck
Mai
HP Photosmart... | Answered on Jan 18, 2018
You may try graphite lubricant like that used on locks. As long as you apply it lightly and only to the bar, it should help the squeak.
HP Photosmart... | Answered on Jan 11, 2018
Been on an online chat with HP in INDIA for over an hour. Given that you would "think" the error might have to do with the inside or "ink" you would think they would have me open the machine. If there is enough room you've got to read this online chat. WORTHLESS and I will never buy another HP printer ever again. This All-in-one was 372 days old and for them to not even consider going inside but to immediately tell me to buy another one. I hope you can see all of this. If not email me at SusanVette [at] ya hoo dot com and I will share it with you. Doesn't all fit so here is their bottom line:
Sequoia: I wish to inform you that HP is providing an option to exchange this defective unit with a new released All-in-One unit.
Susan : How much?
Sequoia: Let me also explain the complete process in detail so you can pick the model that suits your requirement.
Sequoia: You can upgrade the defective printer for a upgraded printer. Under the upgrade option, you have the option of buying a upgraded printer at much lower prices.
Sequoia: It means, we will send you with the another printer with a minimal cost (which is equivalent to the service charges for repairing your defective printer) then we will take your defective printer.
Sequoia: Moreover, the shippment charges will be borne by us.
Sequoia: Would you be interested in looking at these options?
Susan : yes how much
Sequoia: We have HP Photosmart C7280 All-in-One Printer, Fax, Scanner, Copier.
Sequoia: You can use the same cartridges with this model.
Sequoia: The features of this model are:
• Built-in wireless and Ethernet connectivity
• Easy two-sided printing
Sequoia: The Actual price of this All-in-One is $299.99 *
Sequoia: However, under upgrade option HP is offering for $157.99
Susan : how do I proceed when i am ready as I want to read all the reviews on that particular model
Sequoia: I am afraid this offer is not applicable in hpshopping.com or from stores, as this offer is only applicable online from us.
Sequoia: If you would like to go ahead I shall arrange a call back for you so that you can order the printer directly from our call back team.
YADA YADA YADA... Write me at above email for full chat.
HP Photosmart... | Answered on Jan 07, 2018
Tip
How to Print a CD Cover on an HP Photosmart 3.5
You can use the software that came with your HP Photosmart all-in-one printer to create CD covers and then print them on the discs. For this to work, the CD must be printable, and you shouldn't use CDs that have their manufacturer, size and speed already printed on them. You must use the latest HPsoftware to create and print the covers. If you can't find the installation disc that came with your printer, download the latest version of the software from HP's Support website.
Launch the HP Solution Center that was installed on your computer when you installed the HPsoftware.
2 Click the "View Library" button to open the photo library and then select the folder that contains the images you want to use for your CD cover from the left pane. Click the "Add This Folder" to add the folder to the library. You can only use photos from the library to create the CD cover.
3 Click the "Back" arrow near the top of the window to return to the Welcome screen.
4 Click the "Create" button, choose "Disc Labels," and then click either "Standard CD" if you want to print on a standard CD or "Mini CD" if you want to print on a mini CD. Click "Choose This Format."
5 Choose a design from the list of designs, and then click the "Choose This Design" button.
6 Select the photo or photos you want to print on your CD, and then click the "Add These Photos" button.
7 Use the controls in the Edit Your Disc Label section to zoom, rotate and reposition the photo. Click the text boxes and type or paste some text, if you want to add text to the label. Click "Create" when you're satisfied with the result.
8 Select the HP Photosmart printer from the "Printer" drop-down box, and then ensure the "Standard Sizes" option is selected.
9 Click the "Print" button when you're ready to print the cover on the CD. The "Open CD/DVD Tray" message is displayed on the printer's LCD.
10 Pull the CD/DVD tab below the main tray to remove the CD holder, and then place the disc on the ring of the CD holder with its print-side up. Gently press on the CD until it snaps into place.
11 Lower the CD/DVD tray located just below the control panel, and then insert the CD holder into the tray. The printer starts printing as soon as the white lines on the tray and holder match up.
12 Wait until the printing process is complete, remove the CD holder from the tray, let the ink on the CD dry for a few minutes, and then remove the disc from the holder.
13 Close the CD/DVD tray, and then insert the CD holder back into the storage space.
Tips
  • checkPhoto Creations, the latest software from HP, does not support printing CD labels. HP Photosmart Essential is available for download from HP's FTP website (link in Resources).
  • checkThe back of the HP all-in-one printer must be at least three inches away from the wall or other objects.
  • checkIf you use a small CD, don't forget to flip the holder ring over the disc before you snap the CD holder into place.
  • checkYou can add additional folders to HP Photosmart Essential if you can't find the photos you want to print on the CD.
  • checkYou can bold or italicize the text when you type it, but you can't choose a different font or change the size of the text.
  • checkAlternatively, you can use a free third-party utility to create the CD cover and then print it on the disc.
Warnings
  • closeDon't turn off or unplug the printer from the computer while it prints the CD cover.
  • closeInformation in this article applies to HP Photosmart Essential 3.5. Procedures may vary slightly or significantly with other versions or products.
https://itstillworks.com/print-cd-cover-hp-photosmart-38213.html
https://support.hp.com/gb-en/document/c01480130
Printing on CD DVD with Photosmart D7560
How to print cd covers with HP Photosmart Essential 3 5 Google Search
on Dec 15, 2017 | HP Photosmart C6180 All-In-One...
HP Photosmart C6180 All-In-One InkJet Printer Logo
2,298 questions posted
Clive
Clive
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
hp photosmart c7280 ink system failure
  • Office Equipment & Supplies
