20 Most Recent HP Compaq Presario V2000 Notebook Questions & Answers
Get a DVD Ripper:
You can google "DVD ripper" for more selections
Heres one of the top ones:
http://www.dvdtox.com/dvd_ripper.htm
-Cam
HP Compaq... | Answered on Jun 20, 2018
pls send compaq notebook presario v2000 audio driver
HP Compaq... | Answered on Jan 17, 2018
I understand that you are unable to install Audio drivers in your Notebook.
This model of Presario has an audio controller that supports the high definition audio. You need to have Microsoft Universal Audio Architecture (UAA) Bus Driver for High Definition Audio installed on the computer before installing the audio driver.
Here is the weblink to install UAA drivers.
ftp://ftp.compaq.com/pub/softpaq/sp30001-30500/sp30301.exe
Please do not click on the link. Copy and paste it in a new Internet Explorer window.
After installing UAA drivers restart the Notebook and then install Audio drivers.
Here is the weblink to install Audio drivers.
ftp://ftp.hp.com/pub/softpaq/sp36001-36500/sp36090.exe
After installing the drivers restart the Notebook to get the changes effect.
I hope this will resolve the issue.
Thanks
HP Compaq... | Answered on Jan 03, 2018
never post passwords in a public forum.
no OS stated but of window 10 safemode is totally different now.
google that, and its like asked 1million + times and same for answers.
sounds like your PC is infected to me
some PCs now, if the OS detects serious problems (corruption)
it goes to safe mode automatically.
my guess is that is what happened.
because going INTO safe mode is more tricky, no more F8 key magic in W10
so what OS< never post any PC questions lacking what OS you run. OPERATING SYSTEM.
HP Compaq... | Answered on Oct 04, 2017
Tip
How do I backup my files and folders in XP?
Windows XP comes with a backup tool called NTBACKUP (NTBACKUP.MSI from Windows XP CD-ROM). In Windows XP Home Edition, this tool has to be installed manually from the CD-ROM, whereas in Windows XP Professional, this tool is installed by default.
Double-click the Ntbackup.msi file in the following location on the Windows XP Home Edition CD to start a wizard that installs NTBackup: X:\VALUEADD\MSFT\NTBACKUP
X:\ refers to the CD-ROM drive-letter
Note: Usually, OEMs such as Compaq, DELL won't ship the Windows XP CD nor they include the NTBACKUP utility by default. You can download a copy of NTBACKUP.MSI here
Backing up your files using NTBackup Utility:
Click Start, Run and type NTBACKUP
Select Backup tab at the top
In the left pane, scroll to the file/folder which you want to backup and put a checkmark on it.
At the bottom, mention the output filename (the backup output)
Once set, click Start Backup button in the right, and again click Start Backup in resulting dialog
NTBACKUP does not have the ability to write to CDs directly. You will need to save the backup to hard drive, then transfer or burn it to a CD-ROM. Also, while backing up several files, make sure you backup the files in separate sets of each max 650MB (so that it fits on a CD-ROM)
See also FREE Windows Backup Software add-on for NTBackup
Enhanced Windows Backup uses Windows' built in backup engine called Windows Backup (ntbackup.exe) which provides state-of-the-art core backup technology. Enhanced Windows Backup substantially extends the capabilities of NTBackup, providing an effective integrated backup solution.
on Jun 19, 2017 | HP Compaq Presario V2000 Notebook
Hello
Sometimes, its the Video Inverter, is damage, or burn.
other than these, check with a monitor, external, and see if you get video.
Carl
HP Compaq... | Answered on Mar 07, 2017
Hello there!
try these page!
Carl
HP Compaq... | Answered on Jan 26, 2017
Htllo there!
there is the solution
Carl
Hello there!
Check those hints!
1) Check the brightness, and contrast keys!
2) sometimes, taking out battery, for 1 minute solve some issues.
3) bad inverter video.
4) select internal video, instead outside video (keyboard)
Sadly could be anything. Did you check that all the cables are connected internally? If the laptop has a removable processor, reseat it.
HP Compaq... | Answered on Dec 14, 2016
Remove A Cmos Battery From A Compaq V2000 Laptop
The Complementary Metal-Oxide Semiconductor (CMOS) in a computer is responsible for storing hardware settings and time on your computer. The CMOS is powered by a small battery and is able to store information whether your computer is turned on or off. While the standard CMOS battery lasts for up to ten years, you may need to replace your CMOS sooner than that. If you password your BIOS and forget the password or need to reset your configuration back to the default, you can remove the CMOS and re-insert or replace it.
Instructions
1. Unplug the computer from the wall outlet and unplug the AC adapter from the computer.
2. Turn your Compaq Presario V2000 face down and slide the battery release latch to the left to disengage the battery from its position. Remove the battery.
3. Unscrew the screws over the hard drive cover, which is located in the lower right corner of the laptop if your laptop is placed with the battery away from you. Lift the hard drive tab, located on the left side of the hard drive, and slide the hard drive to the left to remove it from the computer.
4. Unscrew the single screw located directly under the optical CD/DVD drive. Insert a very thin item, such as a paper clip or pin, into the hole located on the optical drive to open it. Slide your optical drive out of its tray to remove it.
5. Remove the two screws located on the switch cover, which is directly under the battery. Turn the computer right-side up and open it as wide as it will go. Use a flat tipped screwdriver to lift up the switch cover that is directly above the "F1," "F5," "F11" and "Insert" keys.
6. Unscrew the four screws that hold the keyboard in place. These screws are are located in the upper right corner of the computer under the switch cover that you just removed. Lift the keyboard up and slide it forward until it rests on the palm rest. Unplug the zif connector, which is located directly above the palm rest, to disconnect the keyboard. Lift the keyboard up and out of the laptop.
7. Turn the computer upside down again and remove the memory modules by unscrewing the two screws over the memory compartment located directly below the battery slot. Unclip the two clips located on each side of the memory module to release it from its slot and slide it out of the computer.
8. Unscrew the two screws on the PCI cover directly beneath the memory module. Disconnect the two wireless antennas above the card. Spread the two clips securing the mini PCI card into place and lift the card up and out at a 45-degree angle away from you.
9. Flip the laptop back up on its right side and disconnect the display cable located in the upper left corner above the keyboard area underneath the switch cover you removed earlier. Then remove the two pieces of tape in the upper right corner that hold the wireless antenna in place. Remove the two clips located beneath the tape pieces. Unscrew the two screws on the upper left corner and the two in the upper right corner that hold the display into place. Remove the display assembly.
10. Turn the computer back upside down and remove the remaining 19 screws. Lift the base enclosure straight up out of its place.
11. Locate the CMOS battery, a small circular object, and lift it up out of its place. Leave it out for five minutes and reinsert it to reset your settings. Re-assemble the computer without the battery and plug it into the wall.
Remove Cmos Battery From Compaq V2000 Laptop
HP Compaq... | Answered on Jul 14, 2016
You can set your password to auto login.
Go to start, run, controluserpasswords2, uncheck users must enter the passwords, and click on your account , set the password and off you go. The computer will login to windows automatically after the restart. Regards, Mike
HP Compaq... | Answered on Apr 07, 2016
rpeacock
I can't post a key to MS Office as that is considered piracy. I can however give you a link to a 60 day free trial of office
http://office.microsoft.com/en-us/products/HA101741481033.aspx
After the free trial expires, a license must be purchased.
If you have a legitimate copy of Office Home and Student edition, the product key is on the CD case. If you lost the case, you might be able to contact Microsoft for a new key (For a fee)
HP Compaq... | Answered on Nov 19, 2015
It would seem that your backlight is not turning on.
First check to see if the switch that detects that the lid closed is working. I am not sure where it is on this model, but all notebooks have one. If it gets stuck, the backlight stays off.
If it is not the switch, it may be the flourescent backlight
tubes or the inverter, It's not an easy fix, but you can check back here.
HP Compaq... | Answered on Oct 10, 2015
Your laptop model is notorious for this problem. It is a loose connection with the wires going through one of the hinges of the flip screen. Open up your computer and find a way to plug the wire all the way back in. It can be a frustrating task so be prepared.
HP Compaq... | Answered on Jul 06, 2015
Bad BIOS. Needs a new bios loaded from disc.
HP Compaq... | Answered on Feb 03, 2015
Beep codes are unique to each brand of computer:
Compaq v2000
1 short with 1 long beep = bad bios. Must reload bios from disc.
2 short beeps = general bios failure
for more - do a google search for "v2000 Beep Codes" and go to the link for "bioscentral" - all are listed.
Bad RAM usually causes the computer to crash during the process. An orderly failure to complete the installation usually means a bad hard drive.
HP Compaq... | Answered on Jan 13, 2015
how to video
HP Compaq... | Answered on Dec 16, 2014
HP Compaq Presario V2000 Notebook Logo
1,884 questions posted
Top HP Computers & Internet Experts
Thomas F. Schneider
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Presario HP
  • Presario HP
Most Popular Question
unlock laptop someone
  • Computers & Internet
