20 Most Recent HP OfficeJet 7310 All-In-One InkJet Printer Questions & Answers
Unplug
Wait 20 secs
Plug it back in while holding 6 and #
Continue to hold until a reset notification pops up (this may take a while).
The error may pop up again, just unplug and plug back in and you should be good.
HP OfficeJet... | Answered on Sep 11, 2019
All of the information is in the manual. You can select one here to download:
http://h20180.www2.hp.com/apps/Lookup?h_pagetype=s-003&h_client=z-a-r1002-3&jumpid=hpr_r1002_usen_link1&h_lang=en&h_cc=us&h_query=+HP+OfficeJet+7310
HP OfficeJet... | Answered on Mar 12, 2019
  • click here for driver( HP OfficeJet 7310 All-In-One InkJet Printer)
  • click here for driver( HP officejet 7413 All-In-One Printer)
  • click here for driver(HP officejet 7410 All-In-One Printer)
i hope this will solve your problem
regards,
cseian
HP OfficeJet... | Answered on Sep 21, 2018
Could be several things causing this. You said it is a network printer, but then said primary computer is XP. Is it hooked to the XP machine? From my experience, printers on XP machines occasionally lose their drivers. Go to the XP machine and make sure the printer is in the printer folder, and active. Do a test print to be sure. Then make sure it is still shared (things like this can change with updates). If all this is OK, go to the Vista machine and remove the printer. Then go to add printers, and add a network printer. Sometimes, if it is a network printer, it will show up in "my network" - if so, right click and add printer. If you add the printer usually the computer will use the currently installed drivers. If it is a shared printer, go to network, double click the XP machine, and the shared printer should be there. right click and add. Once you have it working, go to printers and delete or remove the faded-out printers that don't work and be sure to set the newly installed printer as your default.
HP OfficeJet... | Answered on Jun 18, 2018
Remove printhead, see if it is dirty. Clean it and the problem should go away. Also Try clening the contacts on the area where the cartridges touch them.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/alex_22751bbefa74c3d0
HP OfficeJet... | Answered on Jun 17, 2017
Full Reset:
1. Tun Power OFF
2. Wait for 10 secs
3. Turn Power ON while holding 6 and #
4. Continue to hold until a reset notification pops up (be patient).
Note: The error may display again; just unplug and plug the power cord back in and you are good to go.
HP OfficeJet... | Answered on Nov 06, 2016
check the paper tray, make sure the paper guides are snug up to the edges of the paper. Even a small gap will cause miss alignment of the printing.
HP OfficeJet... | Answered on Jul 02, 2016
Check you have colour ink left in the cartridge also check the default printer properties are not set to black and white.
HP OfficeJet... | Answered on May 15, 2016
sorry but there is no make listed other than a HP OFFICejet .try contacting the manufacturer thru their website .
HP OfficeJet... | Answered on Mar 20, 2016
HP OfficeJet 7310 All-In-One InkJet Printer Logo
983 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
OfficeJet HP
  • OfficeJet HP
Most Popular Question
paper feeding crooked
  • Office Equipment & Supplies
