20 Most Recent
HP PSC 2175 All-In-One InkJet Printer Questions & Answers
HP 2175 - downloaded and installed driver but printer not recogni
have you downloaded the correct driver for xp? has your pc got the latest xp driver installer from microsoft installed? there is not a lot of the latest drivers for periphials that will work with xp cos there is no support. try using a older version i loved xp it was a good system but i could not get it to work with later drivers for printers etc.drivers
HP 2175 all in one.
Not sure about your model. But that ribbon is very likely the cord that send information to your print cartridge. It is supposed to be slack so that the print cartridges can move left and right. If you are able to reconnect it and make it stay you should be good. Likely when it is in the furthest position it is getting too tight and coming loose again. Hopes this helps.
Getting red to work
Not sure the make of machine you have but I have had this on a Canon machine it could be the controller board or a diod on the laser unit
Hp printer won't copy
1. turn off / on the printer
2. press setup hold down and press options
3. press start color copy
worked for me on psc 2175
Sue
How to load ink cartridges
It uses cartridges, to change ink cartridge open from the section where the paper comes out from, take a good look you would find a small groove where your finger can enter then pull. while it is ON the ink carrier moves to the convienient position.
