LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
A
Anonymous Posted on Mar 16, 2015
Have an error code f1, unplugged to reset, came right back
Pleazer Appliance
Level 2:
Novelist:
  • Expert 150 Answers
  • Posted on Mar 17, 2015
 Pleazer Appliance
Expert
Level 2:
Novelist:
Answers
150
Questions
0
Helped
81366
Points
240
LG is not showing an F1 to be an error code in their library, could it be a IF? Would you be able to post a pic of the display when the code is displayed?
Jorgie the appliance guy
Level 3:
Top Expert:
  • LG Master 5,639 Answers
LG Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523875
Points
32630
I think that is a fuse blown error code
1helpful
My Hitachi Freez R-W660FEUC9X flashing error code F1 05. Anyone knows what does this mean?
Unplug the LG fridge and wait 20 minutes - Plug back into power - Many times the code will clear or reset. If not keep reading below... -The majority of the time it is the freezer fan causing the Er FF error code. The FF error code indicates that the freezer fan motor is defective.
https://removeandreplace.com/2017/08/27/lg-refrigerator-error-code-er-ff-how-to-clear/
Haier Wine Cellar, Dual model, displays EE error code and was heavily iced on the interior back.
If the refrigerator or freezer displays error code, request a technician to check, please call the service
Different series display different error codes.
The error codes for the refrigerator: F1, F2. F3, F4, F5, F6, F7, EO, E1, E2, E6, Er, Ed, an so on
The error codes for the wine cellar: F1, F2. F3, F4, F5, H1. H2, A1, A2, E1, E2, EE, HH, LL, and so on
Notice: If you power off then power on, maybe the error code disappear, but it will display again after a few hours.
I have an Electrolux gas dryer, front loader and while drying bed sheets it gave the error F1
unplug wait a minute plug back in see if it resets.
most electrolux have E error codes followed by 2 numbers.
Press and hold the "Temperature" and "Dryness" buttons simultaneously for 6 seconds to do a factory reset.
hope this helps.
What foes Error code f1 mean?
Error Code Definition
  • According to Appliance Parts Quick, the error code is defined as a "Primary Control Failure." This means that the small computer installed in the washer has failed to send, receive or communicate with any other part of the washer.
Reset the Code
  • To stop the flashing and beeps on the washer, hold down the "Start" and " Stop" buttons for 60 seconds. If this does not work, unplug the washer for 30 seconds and plug it back it or leave it unplugged since it is inoperable.
Parts
  • The main problem is with the machine control assembly. This whole part needs to be replaced. Depending on your model, prices range from $150 to $260, as of 2011.
Process
  • The installation of the new machine control assembly, requires manual installation and opening the washer itself. If you have never taken apart or repaired a washer, a professional should provide the service and care. Contact Whirlpool support for more information on repairs and warranty.
Read more : http://www.ehow.com/info_7936847_whirlpool-washers-error-code-f1.html
F1 means the central electrical control unit, i.e. the onboard computer, has fatally failed. Unless you have both the skill and tools to test the guts of this computer, you're stuck replacing it. Good news, three screws at the rear to expose the control panel, then unplug one unit; plug in the new one. Just to be on the safe side, color code all the plugs and receptacles. At wholesale, the part is $175.00. CODE 083009 part W10189966 CNTRL-ELEC
Read more: http://forum.appliancepartspros.com/washer-repair/10337-whirlpool-f1-code.html#ixzz3dvEIxJdx
http://forum.appliancepartspros.com http://forum.appliancepartspros.com/washer-repair/10337-whirlpool-f1-code.html#ixzz3dvEIxJdx
I have a frigidaire wall oven showing E r r f1 what is wrong no manual
Typically error code F1 could indicate a variety of issues. The wall oven could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the wall oven by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately
Nov 19, 2012 • GE Ovens
What does err F1 mean?
Hello - Typically error code F1 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
1helpful
Maytag Bravos error code f1
F1 is a very bad error unfortunately. Try unplugging the unit 60 seconds to see if it will reset the control board. If not, then you will need a new relay control board which is about $200, because F1 means that the board has detected an internal short inside the control board itself.
1helpful
Whirlpool WFE381LVB gets F1 error code
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Frigidaire stove(smooth top -electric) all of sudden started to beep' constantly w/F1 flashing.Tried to reset - unsuccessful. Unplugged & waited an hour to plug back in & still beeping...
The F1 error code means a button on the touchpad is stuck,usually pushing clear/off will clear it. Since you have done that and it returns the touchpad needs to be replaced
Gene
Error code F1 and beeping
Means replace the $300 control board. And if your like me.....do it twice within 12 months.
Top LG Refrigerators Experts
ZJ Limited
ZJ Limited
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
