20 Most Recent LG LRFD25850 French Door Refrigerator Questions & Answers
Remove all the food from the freezer and then the drawer from the cabinet. Now using a silicone based lubricant, lube the tracks up real well. Be sure to clean the tracks first if gunked up. Make sure nothing small fell out of the basket over time and is laying on the floor in the rear of the freezer section. Once done, you should be fine.
Eric Campion
LG LRFD25850... | Answered on Apr 03, 2018
Suggest obtain correct valve.
LG LRFD25850... | Answered on Jan 02, 2018
Model number are the best the show techs like myself the configuration of the unit so we can accurately answer your concerns
LG LRFD25850... | Answered on Jan 01, 2018
dispenser panel of what ?? thanks .
LG LRFD25850... | Answered on Mar 05, 2016
The gasket is new and should become less noisy the more often it is flexed.
LG LRFD25850... | Answered on Jan 26, 2016
Check the flap where the ice comes out it may be stuck open which will cause the ice to freeze together
LG LRFD25850... | Answered on Oct 08, 2015
Is that model number LRFD25850 above your post correct? You are talking about the dispenser fountain controls?
Appliance 911 Seabreeze
LG LRFD25850... | Answered on Sep 20, 2015
You need to replace the light or check and make sure your switch is not frozen and being held in
LG LRFD25850... | Answered on Feb 16, 2015
I would suggest you check the seal and the hinge. This frig has a piece that folds in and out flush for the two doors to seal, you might check that as well.
LG LRFD25850... | Answered on Aug 11, 2014
The real problem is that the drain which carries the defrost water away from the coils (and down to the external pan underneath where it should evaporate) has become plugged with ice (from having left the door open thereby icing up the coils and the drain). The problem you have now is that the normal defrost cycle was not designed to melt the ice plug that is blocking the drain. Solution: You have to either (1) if you're handy, you can remove the plastic panel over the coils in the back of the freezer and melt it out with a hair dryer or hot water -- or (2) unplug the unit, leave the doors open and let it melt out by itself. I don't know how long you'd have to wait for (2) to completely melt the ice plug -- I'm guessing at least 24-36 hours to be sure. I did (1) and it took me about 2 hours to remove the freezer bin and door, remove the main drawer slides, remove the internal drawers and their slides, remove the back inside panel, find the ice plug (lower left side of the drip tray under the evap coils), melt it out with hot water from a baster, verify that the drain was clear, reassemble in reverse order. But it worked. Problem completely solved -- no water since. By the way the drip tray was completely full of ice - right after a defrost cycle had completed -- so this problem will never resolve itself without intervention. Bear in mind, the whole cycle COULD happen again if the drawer is left open again and the excess ice builds up on the coils again. This is a design flaw in the unit itself. However, I read about a clever solution to prevent a new ice plug forming as a result of the open door. Just loop a length of 10-12 gauge bare copper wire around the defrost heater element and insert the other end of the wire in the drain hole. Heat conducted through the wire during defrost will clear any ice plug that may form.
LG LRFD25850... | Answered on Aug 06, 2014
do not purchase lg refrigerators or products. they are junk!
LG LRFD25850... | Answered on May 23, 2014
LG LRFD25850 French Door Refrigerator Logo
226 questions posted
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
ice inside freezer door top inside
  • Refrigerators
