20 Most Recent LG LFX25971ST Bottom Freezer French Door Refrigerator Questions & Answers
likely so unless you can get the seal ring. However, it first needs to be determined which part causes the leak as they can be many sources
LG LFX25971ST... | Answered on Dec 10, 2017
This sounds dangerous, I suggest you hire a pro to look into this.
LG LFX25971ST... | Answered on Nov 21, 2017
Arm should not be in up position unless harvest cycle is in progress. Or unless you manually put it there to cut off Ice Maker. Most likely ice maker is defective
LG LFX25971ST... | Answered on Nov 12, 2017
there may be a problem with the water lines or bottles in the fridge compartment is frozen raise the temp in the fridges to about 38 for a couple of days and this should unthaw the lines
LG LFX25971ST... | Answered on Nov 02, 2017
FRENCH DOOR SERVICE MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
LG LFX25971ST... | Answered on Sep 15, 2017
check if the water supply main valve for the unit is fully opened. if it is , check for obstructions in the line. if waterline has no obstructions , find out if water solenoid valve is working fine. with all the mentioned working alright but problem is still present , call a service man .thanks.
LG LFX25971ST... | Answered on Mar 05, 2016
Hello George;
My name is Peter. I am a retired field service refrigeration technician.
The error code is either a bad freezer fan, which is more likely, or a bad control board.
25682632-ebcjyrvherokzlkldixpqrtk-2-0.jpg Motor Part Substitution: 4681JB1027C Cost: $55.00
Part #: EBR41956418 Cost: $125.00
There is a reset button on the board located in the back of your unit. GROUND YOURSELF BY TOUCHING SOMETHING THAT IS BARE METAL. STATIC ELECTRICITY WILL KNOCK OUT A CONTROL BOARD. Push the reset button only once. Open the refrigerator door while holding the light switch button in. Hear the fan?
Go into the following website, put in your model number and select parts. Parts and diagrams will appear.
Water Filters Lawn Garden Appliance Parts
You can purchase the parts for allot less over the internet.
If you call a service company, they will double the cost of the part and probably charge you $250.00 or more for labor. The labor cost for a bottom freezer is allot higher than a side x side or top freezer because of the difficulty to access the freezer components.
Bottom freezers and units with the ice maker or ice bucket on the door are the worst.
On my daily service calls, 65% were for either Samsung or LG.
Next time stay away from these and the above.
LG LFX25971ST... | Answered on May 06, 2015
I think that is a fuse blown error code
LG LFX25971ST... | Answered on Mar 17, 2015
How do you know that it stays on?
LG LFX25971ST... | Answered on Mar 05, 2015
FF is usually a Freezer Fan error code. A qualified service tech needs to look at the unit, checking for iced over fan motor, loose plug connection, ect. Pleazer Appliance...
LG LFX25971ST... | Answered on Jan 17, 2015
Compressor may be bad - do you hear motor running??? It may need freon. Airflow may be blocked -- keep area clear just like intake vents on floor, must be kept clear to allow proper air flow.
LG LFX25971ST... | Answered on Mar 06, 2014
LG LFX25971ST Bottom Freezer French Door Refrigerator Logo
163 questions posted
Top LG Refrigerators Experts
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Jay Finke
Jay Finke
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
lg refrigerator lfx24971st ice naker not
  • Refrigerators
