20 Most Recent Maytag Bravos MTW6600T Top Load Washer Questions & Answers
This machine is equipped with technology that allows it to sense the load size and will use the appropriate amount of water for that load. Takes the guesswork out!
Maytag Bravos... | Answered on Dec 02, 2018
I'd replace lid lock.
Maytag Bravos... | Answered on Nov 14, 2017
Most likely suspension rods and bushings need replacing. Also check outer tub ring. Sometimes it will break from beating on sides of washer, behind where water comes out.
Maytag Bravos... | Answered on Oct 01, 2017
The machine has found a fault.
Maytag Bravos... | Answered on Sep 08, 2017
Hi jbrundage1. I believe you have a UL error code on the washer. It means that the sensors in the washer are sensing the unit is unbalanced. When the washer is empty, set it to a spin or rinse and spin setting. Run the washer through the cycle empty, as it will help to remove any excess water in the tub. Also, make sure the washer is level, as it is balanced on springs, and that could be throwing the sensors off. I hope these suggestions prove helpful. Sincerely, Melanie, Maytag Social Media Representative.
Maytag Bravos... | Answered on Aug 18, 2017
revisit the drain pump and make sure that you have the small "O" ring seal properly installed between the housings
otherwise replace the pump assembly
Maytag Bravos... | Answered on Jul 25, 2017
call out a repairman possibly the tub bearings have begun failing .
Maytag Bravos... | Answered on Mar 14, 2016
I u unplugged the machine and it stopped blinking, the lid unlocked but when I tried starting it again the same thing happened. I cleaned the contacts on the lock but that did not help.
Maytag Bravos... | Answered on Feb 08, 2016
Maytag Bravos MTW6600T Top Load Washer Run ... - Fixya
www.fixya.com > ... > Maytag Bravos MTW6600T Top Load Washer
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test cycle related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer, run diagnostic test ccu related issues. Get free help, solutions & advice from top Maytag experts.
Maytag Bravos MTW6600T Top Load Washer Diagnostic ...
Maytag Bravos... | Answered on Dec 02, 2015
Maytag Bravos MTW6600T Top Load Washer Logo
842 questions posted
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Maytag Washing Machines
Most Popular Question
red lid lock flashing will not operate
  • Washing Machines
