20 Most Recent Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Questions & Answers
Thank you for your inquiry, Cheryl!
I understand that you left the silicone guard on the grates and turned on self-cleaning, now you have white powder inside of your Frigidaire range. This can be removed by using hot water, baking soda, and a non-abrasive cloth. It may take elbow grease in order to remove the white powder. I would recommend not using the oven until you have removed the white powder. I hope this information is helpful for you. -Matt
Frigidaire 30"... | Answered on Jan 06, 2019
my frigidaire oven will not light. The broiler works and the oven ingiter lights up, but the oven will not ingite. The electronic display does work.
Frigidaire 30"... | Answered on Jan 05, 2019
you can find your model number behind the drawer
sometimes it is on the back side of the drawer front
hope this helps
but to asssure you both have repalceable mylar covers
Frigidaire 30"... | Answered on Dec 29, 2018
Control pcb is faulty.
Frigidaire 30"... | Answered on Sep 22, 2018
Hi Elizabeth! From what you have posted, your appliance is experiencing a high-temperature error code (F10). A high-temperature error indicates that your oven has reached too high of a temperature for too long of a time period. If unplugging your appliance does not prove to be successful, you would require a visit from a professional to check the temperature sensor and the electronic oven control (brains of your appliance behind the touch pad). If you have any other questions please comment so I can help!
Thanks,
Chris
Frigidaire 30"... | Answered on Jul 08, 2018
Good Afternoon Friend, this is Z. Thank you for your post!
I understand you are seeking the fuses location in your Frigidaire range. May I please have your model number? You can typically locate the serial tag (which lists your model number) in the storage drawer, on the right side. Please describe what your appliance is doing so that I can assist you better in pinpointing the problem before you take this step. Thanks!
Frigidaire 30"... | Answered on Apr 22, 2018
clean it the other way spray cleaner and wipe out
Frigidaire 30"... | Answered on Feb 07, 2018
push in on the oven light switch and hit clean then cancel you have to hold the oven light switch thats what tells the eoc the door is closed if this dont work reply to me
Frigidaire 30"... | Answered on Feb 03, 2018
total cost of blouses p2400
16 sold at p145 = 2320p
p2400 - p2320 = 80p loss on original stock cost
to make a p480 total profit p480 + 80p(cover loss) = 560P
560P /4 = 140p
560p +2320 p = 2880 ptotal proceeds
profit = proceeds - original stock cost
profit = 2880p - 2400p
profit = 480p
Answer is 140p
Frigidaire 30"... | Answered on Jan 26, 2018
Maybe your knob is turning but the rod the knob is connected to is not turning. Best to remove knob and turn the rod to off position with Pliers to be sure it is actually being turned to the off position.
Frigidaire 30"... | Answered on Jan 15, 2018
If the burners and oven light are working, then you have power coming in. It's most likely a defective EOC. If you haven't tried turning off the circuit breaker for 5-10 mins to reset any glitch associated with a surge or spike, do so. If this doesn't reset the control, the EOC will need to be replaced.
Frigidaire 30"... | Answered on Jan 05, 2018
My oven door stays locked , when I press the clear button I get F1?
I hold the clear button for a few seconds and still nothing.
Please,
Thank You
Frigidaire 30"... | Answered on Dec 28, 2017
you either have a bad latch assy. or a bad computer board or a broken wire.this can be an expensive fix and the problem with self cleaning ovens is when you self clean them the temp. gets up to 1000 degrees and this damages the electronics in the machines,personally i would never use the self clean feature i clean mine by hand with easy off.people do this near the holidays and then the oven doesn't work parts have to be ordered and it could take up to 5 to 10 days or longer to get parts.don't ever self clean your oven when a holiday is coming up so this doesn't happen.if you can still use the oven just forget about the self clean if the error keeps you from cooking you'll have to find out what part is bad to fix it it sounds like your latch is working this code means the computer board thinks the door isn't locked if you want to change out the latch motor it's pretty easy,unplug the oven,pull it out and remove the back wall,the motor will be on the top right hand side looking at the unit from the back the part number is 316464301 this part is around 55 to 75 bucks depending where you get it now if it still does it the clock assy. is around 300 bucks part 316207600 so i would change out the latch assy. first if you need this repaired.hope this helps you out one more thing did you try unplugging the oven it could reset the computer board,leave it unplugged for 10 minutes and then plug it back in,don't try to self clean it,put it on bake and if the code doesn't come back great who cares about the self clean
Frigidaire 30"... | Answered on Nov 13, 2017
This is a problem with a bad door gasket, or a mis-adjusted latch. That needs to be addressed, then you can replace the discolored parts. The discoloration is permanent.
Frigidaire 30"... | Answered on Oct 24, 2017
when cleaning got cleaner on ignitor replace
Frigidaire 30"... | Answered on Oct 08, 2017
possible bad transformer or control board
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
1,336 questions posted
Top Frigidaire Ovens Experts
Craig Butler
Craig Butler
Sal De
Marvin
Marvin
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
View Most Popular
Frigidaire Ovens
  • Frigidaire Ovens
Most Popular Question
frigidaire ples399ecg
  • Ovens
