20 Most Recent Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel Questions & Answers
very possible that it froze the liquid gas in the line at the regulator
Frigidaire 30"... | Answered on Sep 16, 2017
Hey friend, thank you for your post!
I see your oven lock light is flashing and the oven is not working on your Frigidaire range. Are you able to provide model number, with that information I can research any additional information for your range. You can locate the serial tag (which lists your model number) behind the bottom drawer of your range. Thank you for the post and I look forward to assisting you. -Matt
Frigidaire 30"... | Answered on Sep 30, 2014
Good Afternoon Friend,
I see that you are having trouble with your Frigidaire freestanding gas range showing an F11 error code. F11 means your appliance has detected a Shorted Key, which could also be a key that has been detected as pressed for a long period of time. This will terminate all oven activity. What you can do is to press the "Clear" key and if that does not work you will want to give your range a hard reset. You can do this by either unplugging it or cutting the power at the circuit breaker for 2-3 minutes.
After restoring power you will need to reset the clock. You will do this by entering in the time and pressing start.
Turn the oven on and if you are still receiving the F11 error code, I suggest either contacting the manufacturer or contacting your local authorized technician to diagnose your appliance. Hope this helps.
-Best Regards-
WP
Frigidaire 30"... | Answered on Apr 08, 2014
What is the unit model number?
Frigidaire 30"... | Answered on Oct 20, 2013
Hello Debbie - Sounds like the unit has loss some of its heat inside of the oven cavity. This means it cannot reach the proper preheat temperature in the programmed 30 minute timeframe. A technician would be required to further diagnose this concern. They would most likely assess the convection heating element, thermal cutout, thermal oven sensor and all wired connections for repairs. Lastly the oven cavity and insulation should be checked to ensure there are no gaps or damages that will leak out the heat. At t his time, I would recommend contacting a professional to assist you further.
Frigidaire 30"... | Answered on May 31, 2013
Hello bdrillbit - Is the electronic igniter aligned properly? Ensure that tip of spark igniter is aligned with metal point or "nib" located on underside of burner cap after the burner mounting screws have been tightened. (Not all burners having mounting screws). When the burner control knob is set to the "LITE" position do the igniters spark? Can gas be heard or smelled coming from the burners when the control number is turned on? However, if you smell gas, I highly recommend turning the unit and the gas off if you can reach it and contact your gas provider. The range itself does not have a switch or regulator to relight it. Keep in mind that it may be experiencing an issue with the spark module, electrodes, wiring or EOC.
Frigidaire 30"... | Answered on Feb 14, 2013
how do i change my frigidair cook stove from nataul gas to propane modle fgfl67dck
Frigidaire 30"... | Answered on Jan 31, 2013
You would definitely want to seek out a professional technician to diagnose the unit. Gas units are very dangerous if you are not use to working on them. You could have a slow gas connection or flow, a faulty valve, or bad ignition. All would absolutely need a professional to diagnose and repair, this is not a typical DIY job.
Frigidaire 30"... | Answered on Dec 27, 2012
Hello Lorraine Goudie - What is the concern? Does the bread setting light maintains on? May you please provide me the model number so I can assist you better in pinpointing you the information? Typically the serial tag may be found in the storage drawer, on the right side.
Frigidaire 30"... | Answered on Dec 19, 2012
Smooth side goes to the outside.
Frigidaire 30"... | Answered on Nov 30, 2012
The "F9" error code means the EOC (electronic oven control) has found the lock motor switches to be out of sequence or shorted.
Test switches and if there is nothing wrong then replace the EOC.
What is the model number?
Frigidaire 30"... | Answered on Nov 28, 2012
Hello - Typically error code F10 could indicate a variety of issues. The range could possibly have a runaway temp (higher than normal temps), shorted keypad, faulty EOC (Electronic Oven Control) or, display wire harness missing/not connected. Usually, this code means to replace the EOC. You may be able to reset the range by disconnecting the power to the unit for up ten minutes. Usually this will clear most false error codes. You can disconnect power by either unplugging the unit or flipping the circuit breaker off and back on. If resetting the unit proves to be ineffective, I would recommend contacting a professional to move forward accurately.
Frigidaire 30"... | Answered on Oct 26, 2012
Frigidaire 30" Self-Cleaning Freestanding Gas Range - Easy Care Stainless-Steel Logo
Popular Tags
105 questions posted
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Marvin
Marvin
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
View Most Popular
  • Frigidaire Kitchen Ranges
Most Popular Question
bread setting lite up
  • Kitchen Ranges
