20 Most Recent LG LRTP1231W Top Freezer Refrigerator Questions & Answers
Turn it off. If you keep running it, it will die completely fairly soon. Please feel free to jump to the end if you don't want a fridge science lecture - it might help you figure out the problem though. When a fridge/freezer runs, the condenser (all the tubes at the back) will get warm-hot. That is where the heat goes from inside the fridge. First thing to check; is there excessive heat to remove from the fridge/freezer? Check the door seals are ok - cold air falling out of a bad door seal can make a fridge both cool and warm a room at the same time - which obviously leads to problems Check that the lights inside actually go off when you close the door by pressing the switch that the door usually presses when it shuts, and checking that the door will press the switch as far as it needs to go. Second thing; Check that there is adequate ventilation at the back - remember the ideal situation technically for a fridge is to have the bit at the back outside the house in the shade like an air-con unit. pull the fridge a bit more away from the wall and try blowing a fan onto it. Clean gently with a soft brush any dust etc that is on all the tubes at the back - it can cause an insulating coat to form. If the dust is sticky and hard to shift, then gently use a soft paintbrush and warm soapy water. Third thing; When the amount of refrigerant gas in a fridge system is getting low (they all leak a tiny bit all the time - even without any fault) two main things happen: The fridge gas has a lubricant mixed in with it that keeps the inside parts of the system oiled. when the gas is low, so is the oil and you get the same effect as running a car with no oil - runs hot, then dies. The low gas has an effect inside and outside the fridge - inside, near where the gas first enters the evaporator (the plate in the fridge that gets cold) it will get extra cold. the compressed refrigerant evaporates too quickly - easy way to explain is that there is nothing in front of it in the queue so it runs through too quick. the same thing happens in reverse when the gas goes into the condenser at the back, the gas condenses too quickly making the back very hot. I think, from what you say, that low gas is the problem. Although it is not too complicated, it is illegal for you to do it yourself in most places for environmental and safety reasons - get any fridge repair guy and he can do it and check for leaks at the same time. Hope this helps, and is in time to save your fridge :)
LG LRTP1231W Top... | Answered on Jun 29, 2019
turn the freazer nob to zero for a second or two, the noise will stop. turn it back to your normal setting.
Emad
LG LRTP1231W Top... | Answered on May 31, 2019
Drain in freezer compartment is plugged.
Mold (fungus) buildup sometimes restricts water flowing into condensate tube in the defrost cycle, and water somehow can enter in the refrigerator compartment and out the bottom of the refrigerator door.
You must clean the condensate tube!
You must remove back cover in freezer. One screw in left upper corner behind plastic screw plug will allow you to remove the cover exposing evapourator coil and condensate drain tube hole below it. Must also remove back cover at rear of refrigerator exposing the condensate drain tube END which may be restricted also.Tube must be totally cleared to allow the water created from defrost cycle to exit to the drain pan in the bottom of the refrigerator.
LG LRTP1231W Top... | Answered on Sep 05, 2014
lower the temperature in the temperate control and then lower the humidity control vent to half open on the trays themselves.
the main reason is your temperate is to cold.
LG LRTP1231W Top... | Answered on Dec 30, 2012
I don't know how your unit works but most have a thermostat that opens a vent between the freezer and the fridge allowing cold air into the fridge compartment. you probably need a new thermostat
which looks like a wire with a tube on the end, check for a service manual on the manufacturers website to find part numbers and diagrams
LG LRTP1231W Top... | Answered on Oct 21, 2011
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
LG LRTP1231W Top... | Answered on Jun 02, 2011
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrigerator's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Using a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Hope this helpout......
LG LRTP1231W Top... | Answered on May 17, 2011
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
LG LRTP1231W Top... | Answered on Mar 03, 2011
MOST POSSIBLE YOUR DOOR SEAL IS FAULTY. WHEN YOU CLOSE THE DOOR OF YOUR FRIZZIER OR FRIDGE OBSERVE IF THE DOOR SEAL IS WELL "SUCKED" IN. IF NOT REPLACE THE DOOR SEAL.
LG LRTP1231W Top... | Answered on Feb 02, 2011
heatman101
LG LRTP1231W Top... | Answered on Jan 22, 2011
LG LRTP1231W Top Freezer Refrigerator Logo
50 questions posted
Top LG Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
deecee73
Level 1 Expert
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
LG Refrigerators
  • LG Refrigerators
Most Popular Question
lg model lrtn18320ww
  • Refrigerators
