SOURCE: sony vaio screen dark then light
might be going into a powersave after it boots...try checking the power options
SOURCE: screen appears dark
Have you tried to adjust the brightness to see if it not just on the lowest setting. If that doesn't work you can try to unplug the connection for the lcd and plug it back in to see if that works, if not the the lcd backlight is probably burnt out which would require replacing the whole lcd.
