20 Most Recent BenQ FP71E 17" LCD Monitor Questions & Answers
4answers
BenQ FP71E turns off after 2 secs- Logo flashes then turns off
LCD monitors behaving in this fashion more than likely have a faulty inverter. Refer www.lcdparts.net for solutions.
10/15/2014 10:48:52 AM • BenQ FP71E 17"... • Answered on Oct 15, 2014
2answers
Shadowy/Ghosting Display on my monitor
Check the VGA connector and the cable. It might be loose.
4/9/2011 6:45:19 PM • BenQ FP71E 17"... • Answered on Apr 09, 2011
I just got my new
If you have a video card in it, you need to plug the monitor in to that slot not the on board slot.
2/25/2011 9:42:04 PM • BenQ FP71E 17"... • Answered on Feb 25, 2011
0answers
The screen is on for few seconds with no signal
Hello
Check your cable, ask the cable operator about the signal, if these are OK, then the TV tuner gone faulty which needs repair.
Good Luck
12/13/2010 9:14:55 AM • BenQ FP71E 17"... • Answered on Dec 13, 2010
How to get sound working on a Benq 17" FP71E?
is on the back audio input connector, and you can set audio levels on the monitor menu items.
11/7/2010 12:26:56 AM • BenQ FP71E 17"... • Answered on Nov 07, 2010
Have removed 1st monitor and
If you are using two monitors then swap them around.
10/27/2010 4:02:36 AM • BenQ FP71E 17"... • Answered on Oct 27, 2010
The screen seems to be slowly turning white.
More than likely a manufacture defect. If it is not that old; I suggest contacting the manufacturer to get it replaced. Most LCD"s have 1 year warranty, and it's certainly, not weird to see 3 years.
7/24/2010 2:07:11 AM • BenQ FP71E 17"... • Answered on Jul 24, 2010
Sound does not work
We need to find first if the problem is in the monitor or in the sound card in the PC (hopefully you have the audio cable hooked up correctly, Green audio line out of PC goes to green audio line in of the monitor). Try feeding it with MP3 player or sound source to see if you get the sound or not and go from there, please post back. If it is bad amplifier in the monitor, you will be better off putting money toward Good powered speakers that will have 100% better sound than the tiny speakers inside the monitor that sound like tinned can.
http://s807.photobucket.com/home/budm/allalbums
5/22/2010 12:53:54 AM • BenQ FP71E 17"... • Answered on May 22, 2010
When I try to turn the BenQ FP71E 17
Since Dell monitors are made by BenQ, please look at Dell photo albums.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
5/19/2010 3:02:30 PM • BenQ FP71E 17"... • Answered on May 19, 2010
My monitor displays
Hi Geoffrey,
The Issue is that the Serial Slot at the back of the CPU Tower has gone bad,you need to change the Serial Slot in your CPU and then Check it
Regards,
Ayyasam
4/3/2010 11:05:27 AM • BenQ FP71E 17"... • Answered on Apr 03, 2010
Monitor goes white.
if the monitor turn white but the power light is stay on with green, then probably the back light tube was defective, and it will happen randomly in beginning and getting worse after while.
3/22/2010 10:51:14 PM • BenQ FP71E 17"... • Answered on Mar 22, 2010
Logo appears then a blank screen
You need to open it up and inspect the PCB for bad solder connection or over heated components. BenQ made monitors for Dell, so look at some pictures of failed Dell monitors here to get some ideas what could have gone wrong with your monitors, post back what you see so we can guide you further: http://s807.photobucket.com/home/budm/allalbums
3/22/2010 3:01:04 PM • BenQ FP71E 17"... • Answered on Mar 22, 2010
22answers
Screen goes white
Try opening the monitor up, and checking for bad solder joints on the VGA connector. This is actually a relatively common problem, when the monitor gets hot from use, the solder joint begins to fail until it cools down again.
2/20/2010 4:16:52 PM • BenQ FP71E 17"... • Answered on Feb 20, 2010
FP71E+ screen gone pink
If it works fine on another monitor, I'd be inclined to suspect that the inverter is failing, or, you have a loose or damaged connection from the laptop to the screen. It is also possible that the screen backlight is failing. I'd be inclined to suspect the last one as the problem
2/10/2010 9:06:51 PM • BenQ FP71E 17"... • Answered on Feb 10, 2010
Screen auto changes black when conecting
try resetting the brightness control and checking to make sure that the printer cable is securely connected to the computer and the monitor. Your monitor cable may also have a crack or broken wire in it or the connection itself may have come loose.
Try plugging in an external (borrow a friends if necessary) monitor just to check and make sure that the connection on your computer is good and that the problem is not in the wiring of your LCD screen. There are several other things that may help you, let me know if you are still having problems.
2/8/2010 7:15:09 PM • BenQ FP71E 17"... • Answered on Feb 08, 2010
Hi, Monitor will not turn off when computer shuts
Yes its only a raster check of your monitor. YOu may press the power button off .
2/4/2010 3:08:26 AM • BenQ FP71E 17"... • Answered on Feb 04, 2010
My monitor turns white when i turn it on every
Your monitor is about to go out. It may be a faulty bulb if an older monitor or if a newer one which utilizes a plasma or lcd screen, the liquid crystals maybe going bad or the light source could be going bad as well. When LCD's or Plasmas start going bad, the best bet is to get a new one because to fix one is almost as expensive as purchasing a newer one.
11/16/2009 2:11:12 AM • BenQ FP71E 17"... • Answered on Nov 16, 2009
2answers
BenQ Q9T4 monitor displays
If your video card can be remove , try to clean it, but if not buy a new plug and play video card.
your problem is your video card
11/11/2009 4:35:04 AM • BenQ FP71E 17"... • Answered on Nov 11, 2009
BenQ FP71E 17" LCD Monitor Logo
79 questions posted
Top BenQ Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Jean Thiebaux
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
FP BenQ
  • FP BenQ
Most Popular Question
screen seems slowly turning white
  • Computers & Internet
