20 Most Recent Garmin nuvi 205W GPS Receiver Questions & Answers
The problem is with the audio circuitry of the unit. If it is still under warranty, then have Garmin replace it again.
Garmin nuvi 205W... | Answered on Apr 08, 2017
Turn on your Nuvi, go to Tools in the next screen you should see Bluetooth..... go to Connections and Add Device
Once added make sure Bluetooth says Enable
Garmin nuvi 205W... | Answered on Jan 09, 2017
The Garmin Chargers use a 1A 5x20mm glass fuse in the tip.
The DC output of the charger is +5VDC @ 1A. The 1A rating is the max rating and your Nuvi should draw less than 1A under normal conditions.
You would not want to put a 3A in there because if there is a short in the Nuvi, you want the fuse to blow quickly. A 3A fuse is too high in value.
- Jim
SHARCNET-USA
Garmin nuvi 205W... | Answered on Dec 16, 2016
Re-install both the maps and main software through Garmin Express and your PC. Probably more than once or twice before it "takes".
Garmin nuvi 205W... | Answered on Jan 29, 2016
Hello. To reset your home location do the following:
  1. On the main screen touch Tools>My Data>Set Home Location
  2. Enter address, current location, or recently found.
  3. Touch Done.
Please rate this solution if you found it helpful. Thanks, Edward.
Garmin nuvi 205W... | Answered on May 07, 2015
Most likely a defective LCD display. If the unit was dropped, the LCD ribbon cable might have pulled slightly out of the connector on the PCB board.
Garmin nuvi 205W... | Answered on Mar 22, 2015
Plug your nuvi into your PC. Go to the Garmin.com website and log into your account to see your map information. You can go to your account and see the map downloads and reinstall it from there. Or you can download their software "Garmin Express" on your PC. Run the software while your Garmin is plugged into your PC and it will check for any updates for you.
Garmin nuvi 205W... | Answered on Mar 05, 2015
Here is the solution
touch the screen in the right bottom and turn the device on keep the screen pressed. when it asks to reset data select yes
Garmin nuvi 205W... | Answered on Dec 31, 2014
if it can be seen by a computer you may have a chance, otherwise... get a new unit
Garmin nuvi 205W... | Answered on Aug 09, 2014
press the volume button, press the speaker symbol or turn the volume up. otherwise, try a master reset by holding the bottom right corner while powering the unit on. then either use it without sound or get a replacement
Go to WWW.GARMIN.COM to download the latest software. You will need a USB cable and a suitable connector for your Garmin. That should resolve your problem. Also check to see if you are eligible for a FREE download of the maps.
Garmin nuvi 205W... | Answered on Aug 03, 2014
they are fixed in you have to take the hole thing to bits
Garmin nuvi 205W... | Answered on Jul 27, 2014
Garmin nuvi 205W GPS Receiver Logo
836 questions posted
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
View Most Popular
nuvi Garmin
  • nuvi Garmin
Most Popular Question
no map info nuvi 205w
  • GPS
