20 Most Recent Apple iPhone Smartphone Questions & Answers
4answers
2answers
How do I delete photo albums from my Iphone, stop
Yeah, It will stop syncing them and delete them from the phone
10/6/2023 6:40:58 PM • Apple iPhone... • Answered on Oct 06, 2023
How do you replace an iPhone screen?
iPhones are known for their sleek design and advanced features, but their delicate screens are susceptible to cracks and damage from accidental drops or impacts. If you find yourself with a cracked iPhone screen, you may be wondering how to go about the repair process. In this guide, we'll walk you through the steps for replacing your iPhone screen or seeking professional iPhone repair services. DIY iPhone Screen Repair: Note: Performing a DIY iPhone screen replacement can be challenging and may void your warranty. Proceed with caution. Tools You'll Need: Replacement iPhone screen (compatible with your iPhone model). Screwdriver set (including a Pentalobe screwdriver). Plastic spudger or case opening tool. Tweezers. Heat gun or hairdryer. Suction cup. Adhesive strips or adhesive glue. Steps: Power Off the iPhone: Ensure your iPhone is powered off to prevent electrical hazards. Remove the Screws: Use the Pentalobe screwdriver to remove the screws securing the iPhone's casing. Keep track of their sizes and positions. Open the iPhone: Carefully use a plastic spudger or case opening tool to separate the two halves of the iPhone casing, starting from the edges. Disconnect the Battery: Before proceeding, disconnect the battery to ensure safety. Locate and disconnect the battery connector. Remove the Broken Screen: Gently lift and remove the damaged screen from the device. Be cautious of any remaining glass shards. Install the New Screen: Attach the new screen to the iPhone, aligning and securely connecting all the required cables. Reconnect the battery. Secure the Screws: Reattach the screws in their original positions, ensuring they are tightened correctly but not over-tightened. Test the Screen: Power on the iPhone and test the new screen for proper functionality, checking for touch responsiveness and display quality. Apply Adhesive: If your replacement screen lacks pre-installed adhesive, use adhesive strips or glue to secure the screen to the device. Reassemble the iPhone: Carefully snap the two halves of the iPhone casing back together, ensuring all clips are secured. Power Cycle: Turn off and power on the iPhone to confirm that everything is functioning as expected. Professional iPhone Repair: If you're not comfortable with DIY repairs, it's advisable to seek professional iPhone repair services. Look for a reputable repair center or an Apple Authorized Service Provider in your area. These experts have the skills, tools, and genuine replacement parts to ensure a reliable and safe repair. In conclusion, whether you choose to replace your iPhone screen yourself or opt for professional repair, it's crucial to handle the process with care and precision. A cracked screen doesn't have to be a permanent issue, and with the right approach, you can restore your iPhone to its full functionality and visual appeal. For more help visit: https://justrepair.net/
9/15/2023 8:03:08 PM • Apple iPhone... • Answered on Sep 15, 2023
2answers
I have an iPhone 11 and Slotomania VIP /Inner Circle app will not load.
Question edited for clarity. Question moved from Android to iPhone! Open a support Ticket with them. We can't help with that type of problem that is individual to your account and privileges. https://playtikaprod.service-now.com/sm ..
8/26/2023 10:14:14 AM • Apple iPhone... • Answered on Aug 26, 2023
6answers
3gs iPhone froze at boot screen (apple logo)
Re-download the ipsw file that was on your iPhone, Download Spirit to jailbreak, and that should do the trick.
9/8/2022 9:42:32 AM • Apple iPhone... • Answered on Sep 08, 2022
5answers
My screen is stuck on plug into the itunes screen
Probably something went wrong, and your iPhone itself sees that too. That's why your iPhone asks to connect it to your PC or Mac with iTunes installed. -Start iTunes on your PC or Mac -Connect your iPhone to the PC or Mac -Probably iTunes will advise to recover your iPhone. >>If you didn't make regular backups of your data you probably will lose the data that's on your iPhone.<< -Wait until the recovery procedure is done and see if your iPhone works again. What if iTunes doesn't recognize your iPhone anymore in iTunes? Thy a "soft reset' by pressing the ON/OFF button on top of your iPhone and the round menu button underneath your screen simultaneously until your iPhone reboots. Check if your iPhone connects to iTunes and try the recovery. I hope this will help you solving your problem.
9/5/2022 9:52:53 AM • Apple iPhone... • Answered on Sep 05, 2022
4answers
My apple iphone froze on the apple logo
Connect your phone to the computer and open iTunes. Hold both the home key and the power button until the iPhone turns off. Continue to hold them both for 5 more seconds. Release the power button but continue to hold the home button for 10 - 15 more seconds. I tunes should detect the phone in DFU mode. Restore firmware from this mode.
8/31/2022 6:23:29 AM • Apple iPhone... • Answered on Aug 31, 2022
2answers
I had by mistake upgrade
UNLOCK IPHONE ANY MODEL AT HOME ----- NEW Unlock iCloud ----- PHONEUNLOCK.ORG www.phoneunlock.org Unlock iCloud, iCloud Removal Service Unlock iPhone All Models - iCloud Activation Lock - iCloud Passcode - Fingerprint - iPhone 8 Face ID - Find my iPhone - iCloud Owner Message - iCloud Lost mode with Owner Message - Blacklisted - iCloud Blocked Device - Factory Lost - Untrusted Device - Unlock iPhone ALL Models Network Mode - Unlock iPhone SIM Lock Available for iPhone X, 8 Plus, 8, 7 Plus, 7, SE, 6S Plus. 6S, 6 Plus, 6, 5S, 5C, 5, 4S, 4 on all iOS and iPad Versions. Tested and reviewed by https://unlock-icloud.com Get and Download Now iCloudRemover Unlock Tool Start unlock at Home or Office http://phoneunlock.org iCloudRemover Unlock Carrier List (GSM, CDMA carrier unlock mode IMEI unlock changer) Unlock iCloud iPhone Airfire Mobile Unlock iCloud iPhone ASTAC Unlock iCloud iPhone Asset/Vada Wireless Unlock iCloud iPhone AT&T (all) Unlock iCloud iPhone Broadpoint Unlock iCloud iPhone Big Sky Mobile Unlock iCloud iPhone Calhan Wireless Unlock iCloud iPhone call4care Unlock iCloud iPhone Cellular One of East Central Illinois Unlock iCloud iPhone Cellular One of East Arizona Unlock iCloud iPhone Cellular One Nation Unlock iCloud iPhone Cellular One TXOK Unlock iCloud iPhone Chariton Valley Wireless Unlock iCloud iPhone Cincinnati Bell Wireless Unlock iCloud iPhone Commnet Wireless (also uses CDMA in some areas) Unlock iCloud iPhone Consumer Cellular Unlock iCloud iPhone Cordova Wireless Unlock iCloud iPhone Corr Wireless Unlock iCloud iPhone Cross Communications Unlock iCloud iPhone vDTC Wireless Unlock iCloud iPhone Earthtones Unlock iCloud iPhone Epic PCS Unlock iCloud iPhone FreedomPop Unlock iCloud iPhone Fuzion Mobile Unlock iCloud iPhone GCI Wireless (also uses CDMA in some areas) Unlock iCloud iPhone GTC Wireless Unlock iCloud iPhone GoSmart Mobile Unlock iCloud iPhone i wireless Unlock iCloud iPhone Immix Unlock iPhone Indigo Wireless Unlock iCloud iPhone Jolt Wireless Unlock iCloud iPhone KTC PACE Unlock iCloud iPhone Long Lines Wireless Unlock iCloud iPhone Mobal Freedom Unlock iCloud iPhone Metro PCS (also uses CDMA in some areas) Unlock iCloud iPhone NEP Wireless Unlock iCloud iPhone Pine Cellular Unlock iCloud iPhone Plateau Wireless Unlock iCloud iPhone Pure Prepaid Unlock iCloud iPhone Pure Talk USA Unlock iCloud iPhone Simple Mobile Unlock iCloud iPhone Telecom North America Mobile Inc Unlock iCloud iPhone TerreStar Unlock iCloud iPhone T-Mobile USA Unlock iCloud iPhone TracFone Wireless (also uses CDMA in some areas) (Includes NET10 Wireless, SafeLink Wireless, Straight Unlock iPhone Talk, SIMPLE Mobile and Telcel Am?rica) Unlock iCloud iPhone Tru Unlock iCloud iPhone Union Wireless Unlock iCloud iPhone Viaero Wireless Unlock iCloud iPhone Wal-Mart Family Mobile Unlock iCloud iPhone West Central Wireless Unlock iCloud iPhone Westlink Unlock iCloud iPhone XIT Communications Unlock iCloud iPhone Vodafone Unlock iCloud iPhone Orange Unlock iCloud iPhone Telekom Unlock iCloud iPhone Tim Unlock iCloud iPhone O2 Unlock iCloud iPhone Al Unlock iPhone All Models icloud Unlock iPhone All Models 2 Minute Unlock iCloud iCloud Unlock Reveal Unlock iCloud Tutorial Unlock iCloud Free Video Unlock iPhone by IMEI changer iCloudRemover 1.0.2 Unlock iPhone All Models iCloud Removal Unlock iPhone All Models Remove iCloud Lock iCloud UNlock iCloud Removal unlock iPhone Unlock iCloud iPhone All Models Unlock iPhone iCloud Lock Activate iPhone iCloud Unlock icloud, icloud unlock, UNLOCK ICLOUD, unlock,icloud, icloud lock,remove icloud, icloud unlock,icloud locked, icloud remover, activate iphone, unlock iphone, all, iphone, unlock iphone 7, unlock software, flash software, cell unlock, iphone unlock. Unlock iCloud Service Unlock iPhone iPhone XS iPhone Max Permanently
8/6/2022 9:51:44 AM • Apple iPhone... • Answered on Aug 06, 2022
7answers
Ringtones
You will need to jailbreak your iphone first. Best to use www.ibrickr.com which allows the jailbreak and uploading of applications and custom rings. I have some other software which does this but not as elegantly as ibrickr.
8/2/2022 2:24:50 AM • Apple iPhone... • Answered on Aug 02, 2022
4answers
My iphone is disabled
Hi, what is the generation of your iPhone? Your iPhone is disabled because you tried to unlock it but entered the password incorrectly too many times. You can restore your phone in iTunes then jailbreak to unlock. Please provide more information about your iPhone.
6/10/2022 3:25:08 AM • Apple iPhone... • Answered on Jun 10, 2022
7answers
How to delet all the contacts from iphone
If you are using itunes for windows and have synced your contacts with Windows address books and your contact list is now filles with all of your contacts email addresses, here is a quick way to delete your address book at once.
create 2 empty text files on your desktop and rename them to
AddressBookimages.sqlitedb
and
AddressBook.sqlitedb
copy/overwrite these empty files into " /var/root/Library/AddressBook" folder, using "Ibrickr"
this will empty your contacts list, since all contacts are stored in those two files.
* This wont take effect untill you restart your phone
5/17/2022 2:53:20 AM • Apple iPhone... • Answered on May 17, 2022
5answers
My iphone got stucked on the apple logo
here is a small tutorial that my help you....good luck I hope this helps please don't forget to rate
http://www.youtube.com/watch?v=u4xLvpazV24
4/14/2022 2:28:04 AM • Apple iPhone... • Answered on Apr 14, 2022
2answers
It is pathetic that even AFTER you have purchased
Yes there is another way! In fact, you can do it yourself! It's easy and it's fast. And the great thing is, it's FREE! You'll be using the songs from your own iTunes library.
Click the link below to start making your own iPhone ringtones:
http://www.fixya.com/support/r4753790-make_iphone_ringtone_windows_7_vista_or
For more iPhone / iPod touch tips, click here.
3/5/2022 8:09:53 PM • Apple iPhone... • Answered on Mar 05, 2022
4answers
Problem with iphone the camera shows ablack screen
Clean any debris from lens with soft cloth.
Try and download a free "camera" app from app store.
If app doesnt display camera correctly, restore your iPhone, if still not working your hardware may be damaged.
3/1/2022 11:51:42 PM • Apple iPhone... • Answered on Mar 01, 2022
4answers
Ringtones for iphone
If you want to get frre ringtones off the computer for you i phone then go to youtube and type in ringtones for Iphone and it will show you a variety of clips you can choose from, when you find the one you like, follow it along. You sheould get your ringtones soon after that.
Hope this helps
2/21/2022 10:26:24 AM • Apple iPhone... • Answered on Feb 21, 2022
2answers
I updated by iPhone and now I cannot get my Kindle library to download - it downloads onto my Kindle reader and my iPad ok - have I two Kindle accounts or passwords?
If you're able to sync to your Kindle AND iPad, it sounds like there's an issue with your iPhone and the Kindle Reader app. Try deleting the Kindle Reader app, power cycle your iPhone, then power on, re-download the Kindle Reader app and try your download again. If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
1/25/2022 4:21:43 AM • Apple iPhone... • Answered on Jan 25, 2022
2answers
Hi, my iphone 3g is running 3.0 with ultrasn0w, it
Just like a computer, in order to keep your Iphone working, you must clear out your cache, and cookies. On your menu, select 'Settings" then go to Safari", scroll to the bottom, Click Clear History, next clear cookies, and finally clear cache. You will notice it going a bit faster. Just like a PC, or Mac, you get a bunch of clutter on a wireless connection, it can slow your browsing, and you can even be knocked of the internet. It's good to do once a week if you use your computer a lot.
12/17/2021 7:57:29 PM • Apple iPhone... • Answered on Dec 17, 2021
2answers
How to set my ringtone on iphone 4s
Settings>Sounds will allow you to choose a preloaded ringtone. If you want to choose a custom ringtone you can either buy one from the iTunes Store, or download one to your computer and sync it over through iTunes.
12/17/2021 7:56:56 PM • Apple iPhone... • Answered on Dec 17, 2021
5answers
Iphone is stuck on the apple logo screen
Did you try to reset the phone by pressing the power button and home key?
12/7/2021 2:06:25 AM • Apple iPhone... • Answered on Dec 07, 2021
3answers
I9 phone clock/time always run slow
i think u have activated internet and also activated automatic updation of time. in this case every time u set the time, ur phone connects to the internet and changes the time automatically
11/10/2021 7:17:40 PM • Apple iPhone... • Answered on Nov 10, 2021
8,206 questions posted
Popular Products
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
View Most Popular
iPhone Apple
  • iPhone Apple
Most Popular Question
retrieve one year old text messages off
  • Cell Phones
