20 Most Recent
Sony VAIO VGN-SZ460N/C Notebook Questions & Answers
Sony vaio touch pad not working.
My Vaio touchpad started behaving strange. I could move the curser, but no response on left or right click or double tap. Also found that in any search field or user name fields, the computer would just type endless 9's. My wireless mouse could operate the left and right click buttons, but not move the curser. A suggestion to get the mousepad operating again was to touch any key on the keyboard. This allowed it to function again. Final solution was to remove the battery, then hold down the start key for about a minute, reinsert the battery and start it up. It seems to have resolved the problem. I have a 3 month only laptop with Windows 7 already installed. Hope this helps.
1/17/2015 4:05:54 AM •
Sony VAIO...
Answered
on Jan 17, 2015
Hello my no is 08033771188 my username is chidex45 i forgot my password
To resolve these problems, you can simply change or reset forgotten Windows password with a
Windows password reset disk.
A password reset disk is a flash drive configured with your current
password, specially formatted to reset the password on Windows machine
when you ever forget it. It acts as a key to unlock the account. But the
problem is that we often forgot to create a password reset disk and
cannot log on computer with any user account.Of course, a common solution is to use a third party software, just take
Windows Password Unlocker
for example. It can help you remove lost Windows password including
Windows administrator, user and domain password on Windows
7/Vista/XP/2000/2003(R2)/2008(R2), etc. You can easily reset Windows
password with a bootable CD/DVD or USB flash drive in hand.
4/30/2012 12:37:35 PM •
Sony VAIO...
Answered
on Apr 30, 2012
I have a refurbished Sony
I THINK YOU HAVE NOT INSTALLED THE DISPLAY DRIVERS. SO PLS INSTALL ALL THE DRIVERS AND THEN EVERYTHING SHOULG WORK FINE.
5/26/2011 8:15:59 AM •
Sony VAIO...
Answered
on May 26, 2011
I have a Sony Vaio
The first step should be to browse the producers website to see if there are drivers for Windows 7. If not you can try to install vista drivers for your peripherals many times they work anyway.
3/13/2011 9:04:53 AM •
Sony VAIO...
Answered
on Mar 13, 2011
I need drivers for ethernet
Your Notebook Manufacturing Company SONY says that your Notebook Model
VGN-SZ460N/C is optimized to work with Vista OS only. So the drivers you will be installing for XP may lost some of their functionality under XP platform. Still, you can download all your Notebook supporting drivers from this link.
Download Drivers from here But
remember to select your
Operating System (XP/Vista/Seven) when you will be downloading from the above site.
I hope this will be helpful to you.
12/25/2010 6:38:12 PM •
Sony VAIO...
Answered
on Dec 25, 2010
I am unable to booth up my laptop, nothing comes
It sounds like you might have a fan problem that overloaded your HDD, if this is the case you might need to get a whole new HDD because the information can be fried. If possible, backup your information and install it on the new HDD if that's the case.
2/7/2010 2:50:26 AM •
Sony VAIO...
Answered
on Feb 07, 2010
Ater power switch put on
remove the battery, plug the laptop up into the wall outlet and turn it on. If it boots fine then its your battery. Other then that the possibilities are this.
1. Your Processor has gone to junk
2. your hard drive has fried
3. or the pc board has fried.
Do you hear the hard drive spinning at all? if not this would be the first thing i would check. Only problem only real way to test it at home is if you got an other laptop put it in their and turn it on or buy a new one.
To test the board best way to do is open up your laptop by removing screws on the bottom, and looking over the bored and seeing if you see any burnt areas.
To test the CPU, really isnt a easy way to test this either, other then put a new one in.
IMPORTANT: if your laptop is under warenty opening up your laptop and trying to replace these will avoid your warrenty with this company.
best thing to do if under warrenty is to contact sony vaio,
if not take it to a repair shop, or try replacing the above things, starting with the hardrive
also make sure the ram is pushed into the board. (it looks like a rectangle)
1/12/2010 1:34:09 PM •
Sony VAIO...
Answered
on Jan 12, 2010
Sony VGN-FZ340E system not booting
Surya,
Not booting means what? Does it not go into Windows or does it not finish loading Windows? Please clarify. In the mean time study the following link and tell me what is the problem in details.
1/5/2010 11:15:17 AM •
Sony VAIO...
Answered
on Jan 05, 2010
