20 Most Recent
Sony VAIO FX150K Notebook Questions & Answers
SONY VAIO CMOS BATTERY LOCATION
Correction...
The CMOS battery is located
under the system board, and is not accessible from under the keyboard.
The keyboard has to be removed in order to change the CMOS batter, (another reason why I don't like Sony laptops.)
Below is the batter I just pulled from a user's VGN-FS660\W
I've got a Sony Vaio vgn-Fe31m. When I press the
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately
I have a Sony Vaio
when adding new memory always take all memory out, reinsert the new 256mb stick into the first memory socket dimm1 normally, boot the laptop up, if the laptop boots then fine the memory module is ok, shut down and insert the original 256mb into the second slot, dimm2 then boot the laptop it should now boot normally, if not there maybe problems with the memory slot itself, give it blow to get rid of any dust and try again, if this dosent work post back.
Is the cmos battery on a vaio vgn-fe31m on the
Yes the cmos battery is on the motherboard.
Every motherboard that runs a computer has a backup battery to run the circuit while turned off. This battery runs the real-time clock (RTC) and is referred to as the CMOS battery. By keeping the clock active and running even when the computer is switched off, power up/down cycles can be logged and before the internet, your computer could keep dates accurately. It also serves to maintain the system configuration settings in BIOS memory based on RAM or FLASH RAM.
Sony Vaio PCG-9J3M - where is the CMOS battery located?
You can find CMOS cell on motherbord chipset.
it is in back side of laptop.
Open back side of laptop then find motherbord chipset you can find 1 CMOS cell on motherbord chipset pull that CMOS cell for 15 minutes then all settings are defaults.
