Take out your SD card, turn it over and make sure the switch on the back is not in the "locked" position. Sometimes the switch position can be changed with handled.
Locking the memory card prevents you from taking and adding photos to the memory card. It also prevents you from deleting photos from the memory card. If you want to erase all the photos off the memory card. unlock the memory card, go to the camera's Menu and scroll through the settings ti Format the memory card, then format the memory card.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock: 1. Slide the switch up and down. Repeat this 3 times. 2. Let it stay on the Lock position for 30 seconds. 3. Slide the switch up to unlock the card. 4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting. Memory card write protected, memory card locked, memory card will not read, can't use memory card.
Remove the memory card - take your finger nail and slide the tiny lever that says "lock" on the side of the memory card to the "unlock" position. Then reinsert the memory card and it will no longer be locked.
I don't own this camera but My guess is your memory card is in a LOCK SETTING you need to move the memory card to unlocked " wrirte " so you memory card isn't locked.....
Step 1 remove the card from you're camera
Step 2 there is a small little side on the side of the memory chip move that to the unlock position.
step 3 insert the card and start shooting!
I use a Nikon D300 and have Sandisk Compact Flash memory cards. i ahve not come across this problem but would suggest that you insert the memory card into your camera and reformat the memory card. This should clear any errors in the system BUT IT WILL ALSO WIPE ANY PHOTOGRAPHS YOU AHVE TAKEN when formating the memory card.
