20 Most Recent SanDisk 2GB microSD Memory Card Questions & Answers
go to computer direct the pointer to this pc right click and select (manage) it will take you to computer management select disc management and select the location of the drive you want format
SanDisk 2GB... | Answered on Mar 28, 2018
download a free program called card recovery pro. It will get as many pictures as it can.
SanDisk 2GB... | Answered on Feb 16, 2018
Tip
How to Recover Audio Files from SD Card
This video shows a case where you lost audio files in SD card of camera or cell phone. In fact, data loss due to most reasons could be solved using RePicvid Free Photo Recovery, including formatted or corrupted device. Check this video and know about how to recover lost audio files from SD card.
on Nov 09, 2017 | SanDisk 2GB microSD Memory Card
I had the same problem. The chip is faulty and should be replaced by the store that you purchased the chip. This is no fault on your part and by the way the chip I had was also 4 GB
SanDisk 2GB... | Answered on Oct 01, 2017
I believe the Drive has gone Bad. It does happen where the system thinks th e whole drive is there, but the internal hardware just cannot access it.
SanDisk 2GB... | Answered on Sep 19, 2017
Hi! Maybe what you're talking about is the 'Autoplay' feature of the computer. Autoplay can be disabled at some times so you cannot see it, or Autoplay only displays a view picture 'icon' when there is/are picture/s on your 2gb sandisk sd card.
To manually view your pictures, you can follow this steps:
1. Head on to your computer by clicking Computer on the Start Menu.
2. From there you can see an sd card icon that displays your inserted 2gb sandisk sd card name.
3. Click that icon, then from there you can see and browse the files on your 2gb sandisk sd card, including your pictures.
Click Helpful if this fix your problem :) It would be a pleasure.
Further questions? Comment below! It will be entertained. :)
SanDisk 2GB... | Answered on Aug 18, 2017
The best way to recover deleted photos from memory card is to use some memory card photo recovery software, a good one is asoftech photo recovery. You may refer to this guide
Memory card photo recovery guide
hope this helps.
SanDisk 2GB... | Answered on Apr 25, 2017
Hi, It's easy to recover your lost pictures from your memory card. Watch this video and it will help you to recover them.
Hope my advice can help you.
SanDisk 2GB... | Answered on Jan 05, 2017
my micro sd card has been dlocked by me on my nokia x2 02 mobile and this is not unlocked by any default key please help me.
SanDisk 2GB... | Answered on Apr 17, 2016
micros 2gb
ezit1212lt
SanDisk 2GB... | Answered on Jan 01, 2016
i have a my memory no four met of tha sho unable to fourmet write proteket
SanDisk 2GB... | Answered on Dec 04, 2015
check for sandisk update to your computer; had the same problem with memory sticks and the update corrected the prob.
SanDisk 2GB... | Answered on Mar 28, 2015
Just turn the little switch on the side of the memory chip to the other position and you should be able to write now.
SanDisk 2GB... | Answered on Mar 05, 2015
i am forget memory card password
SanDisk 2GB... | Answered on Feb 26, 2015
SD and micro SD cards have a small slide switch on the edge of the card to protect the data stored on the card. To unlock the write protection move the slide switch to the write position.
Since I was facing the problem when I connected my memory card to the system and accidentally deleted my photos in memory card and came across the recovery software to recover data from memory card and here is download link
SanDisk 2GB... | Answered on Feb 21, 2015
You may try asoftech data recovery which helped me before. You can download trial for free
http://www.asoftech.com/adr/
Please be noted that your phone memory should show as a drive letter in your explorer, if not, you need to take out your memory card and connect using a card reader, or plug-in to card reader slot if there's any on your computer.
SanDisk 2GB... | Answered on Dec 26, 2014
Open the image from your email. See if you can right-click the image and use Save Image... then save to your flash drive.
SanDisk 2GB... | Answered on Nov 26, 2014
Open My Computer after inserting the drive into a USB port on your computer. Right-click on the drive and select Properties. You should get a nice chart with the used and free space!
Put your drive into a USB port; right click on that drive after it appears in My Computer and select Format; set the File System drop-down to NTFS (better file storage space) or FAT32 (more compatibility in older operating systems) and click Start.
SanDisk 2GB microSD Memory Card Logo
1,565 questions posted
Top SanDisk Electronics - Others Experts
k24674
Marvin
Marvin
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
View Most Popular
  • SanDisk Electronics - Others
Most Popular Question
clear sd memory card password
  • Electronics - Others
