20 Most Recent Sony Cyber-shot DSC-W50 Digital Camera Questions & Answers
2answers
Good book for a beginner?
have you set it to macro mode? (little flower icon on the right cursor) this function will allow you to get within about 2cm of the subject, however do not use the zoom as the lens cannot focus close enough. To get results any closer you will be looking at an slr and a budget on a few thousand! If enabling macro and not using zoom to allow the lens to focus doesn't get you close enough in you can always enlarge and crop images. have a look on www.picture-skew.blogspot.com i've taken some macros of flowers and bugs, this camera can capture the hairs on an ants back or the individual lenses of a flys compound lens eye.
persevere with this camera, for a very small budget you will get amazing results, ISO refers to the speed of 'film', it comes from the dark old ages of 35mm film cameras. Basically a low ISO is the lowest sensitivity to light and gives the best image quality, however as the ccd is less responsive to the light the camera holds the shutter open for longer. The higher the ISO the more sensitive the ccd but the greater the noise and lower the quality of picture.
Books, try looking for more photography orientated books and less digital camera based books. An upto date photography book will tell you all the technical information about how to take a good picture for any given senario.
if you would like any further advice email me (address on the blogspot)
11/24/2021 6:30:08 PM • Sony Cyber-shot... • Answered on Nov 24, 2021
2answers
Blured Pictures
When you sent the camera in did they give you a diagnosis? Even set to macro it shouldn't affect wider angle pictures. My money would be on a fault with the autofocus, sony probably should have replaced the unit. I wouldn't give up on sony though, every cybershot i've used (which quite a few) has always given good results and never had a fault. I agree i've seen plenty of dsc w30's/35's/50's/55's etc models on ebay with breakdown problems of one sort or another, but all manufacturers have problems.
9/13/2021 8:19:33 AM • Sony Cyber-shot... • Answered on Sep 13, 2021
2answers
Dark screen
Please check your user manual. There is an save mode. Leaving the save mode will solve the problem. If you need more help please advice.
1/17/2021 11:21:57 PM • Sony Cyber-shot... • Answered on Jan 17, 2021
Error E91:01 on DSC H7
If the camera works in all other respects, then that has something to do with the flash setting or some other setting in the menus. But this sounds like something with the flash directly.
Here is a link which may be able to help on the DSC H7: http://www.aakatz.com/whitepaper/whitepaper/appendix2.htm
Try also to reset all the menu setting back to what it was for the factory. Most digital cameras have a setting for that, and usually is something like "RESET ALL" or something close to that.
If nothing works, then the camera needs repair. This is an error to do with the flash only, it appears. So some of the internal parts could be weak, thus causing the error.
10/19/2020 12:15:38 PM • Sony Cyber-shot... • Answered on Oct 19, 2020
2answers
Regarding fixya forum . query regarding cam issues
I just read that post you're referring to I think... I tried it on mine however it didn't solve my problem but it might solve yours...
Here goes...
-push menu
-arrow all the way over to the right until you get to settings
-arrow down two click till you get to setup 1
-go down to initialize and click ok
-it will turn on and off then you need to re enter time and date
hope thats what you wanted...
11/30/2018 9:48:55 AM • Sony Cyber-shot... • Answered on Nov 30, 2018
2answers
W55 Flash dead, E:91:01
I googled this error and found a few relevant links:
http://forums.dpreview.com/forums/read.asp?forum=1009&message=20161066
http://www.fixya.com/support/t427780-e_91_01
11/30/2018 9:40:30 AM • Sony Cyber-shot... • Answered on Nov 30, 2018
0answers
I have a japanese sony cyber shot dsc-w50 how can i change the language from japanese to english
Press the MENU button. Select the toolbox icon. Select the toolbox-1 icon. Select the "A" icon.
7/6/2016 1:57:27 PM • Sony Cyber-shot... • Answered on Jul 06, 2016
How do I fix a sticking lens?
hi, if when the camera is making a whirring noise when switched on the gears are either misaligned or damaged , with camera on slap the base of the camera using your palm, a couple of times should be enough, if this does not help , look closely at the lens if the lens is not straight , gently try a straighten the lens using your thumb and fore finger very gently , you will hear a light click , if this does not work , then the service center ,
2/3/2016 12:38:06 AM • Sony Cyber-shot... • Answered on Feb 03, 2016
42answers
Sony Cybershot dsc w55 Access Problem
I was ready to throw the Damm thing.. tried pulling on the lens.. no good.. but banged the bottom of the camera on the table and it worked!!!! Started out softly and increased the banging and it real really worked.. Sony needs to get their act together... this is serious business..
8/26/2015 10:16:08 PM • Sony Cyber-shot... • Answered on Aug 26, 2015
My digital camera seems to have lost my holiday photos. The memory card is inserted but I get a message saying no file.
active your foto again with the help of recevory software do this.
6/12/2015 7:00:42 PM • Sony Cyber-shot... • Answered on Jun 12, 2015
I have a black spot on my lens of sony digital camera. When i develop photos it is seen. have tried to clean it but it is stll seen.
Check your front of lenz there are some things cleans it.
6/12/2015 6:57:57 PM • Sony Cyber-shot... • Answered on Jun 12, 2015
22answers
Access Probelm with DSC-W50 camera
I was having the exact same issue with my dsc-w55 and I followed the solution of another post from this site which was: "There is a problem internally with the lens. Likely, the focusing lens is jammed up. The lens will need to be disassembled and fixed, if possible, or replaced. Occasionally, a good "whack" in your hand can fix it. Just don't hit the lens, or lcd; or you can break them. Then there will be more damage." I gave it THREE good "whacks" in the palm of my hand, was careful not to hit the lens or LCD and VOILA! I just shot a few pics with my camera and so far so good. Good luck!
1/31/2015 9:33:32 PM • Sony Cyber-shot... • Answered on Jan 31, 2015
Sony Cyber-shot DSC-W50 Digital Camera Logo
1,064 questions posted
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
View Most Popular
Sony Cameras
  • Sony Cameras
Most Popular Question
problem few month ago camera result got
  • Cameras
