20 Most Recent Nikon D90 Digital Camera with 18-105mm lens Questions & Answers
exactly the same problem in Hong Kong. Live view isn't working. turn on-off, change battery, reset setting, format memory card wouldn't work or solve anything. just send it back to customer service centre.
Nikon D90... | Answered on May 16, 2018
If it's inbetween the lens elements, there's no way you can get at it. It would have to be taken apart by a service facility recommended by the manufacturer.
Nikon D90... | Answered on Nov 14, 2017
Have you tried using a different lens ?
Nikon D90... | Answered on Sep 10, 2017
If you did not set write protect on the card before you attached it to the computer, it may have got corrupted. If you are sure all the images are backed up, format the card in the camera.
Nikon D90... | Answered on Jul 21, 2017
Carefully drill a small hole (2-3mm diameter) into the visible end of the battery (drill as close to the flat edge as you can and in the middle to avoid the cells). Then swrew in a small screw - this should allow you to pull the battery out.
Nikon D90... | Answered on Dec 23, 2016
Hi are you using the pop-up flash or an external flash?
Nikon D90... | Answered on Aug 09, 2016
With a small screw driver, GENTLY push the battery side to side and back and forth. If there is room try to pinch with two small screwdrivers and pull. Sounds like it might be corroded in place.
Nikon D90... | Answered on Jul 03, 2016
NONSENSE take the photos you want and see what you get when printing.
Nikon D90... | Answered on Sep 22, 2015
I couldn't find a reference to a blinking green led when the d90 is off.
I would refer you to Nikon tech support for this one.
http://imaging.nikon.com/products/imaging/worldwide/index.htm
The above link has 1-800 numbers for Nikon.
Nikon D90... | Answered on Jun 12, 2015
I'm experiencing similar problem, but when i connect it to computer via USB , it seems to go away.
Problem resurfaced again after a week.
If you do not have a manual for your D90, you can download it free from the Nikon USA website by following this link: Download Center. Go to page 25 in the manual for complete illustrated instructions.
Nikon D90... | Answered on Jun 08, 2015
That is most likely the TTL preflash and should not show up in your final exposure.
Try setting the flash control to manual (e2 under the Bracketing/Flash menu). That should give you only the one flash at the end.
Aaron Gum
Nikon D90... | Answered on Feb 11, 2015
You could simply go to Nikon's software download page and download the programs. You can register those programs you wish to purchase, and burn to a blank CD.
If this is not what you're looking to do, contact Nikon Customer Service and explain what you'd like to do.
I hope this helps - good luck!
Personally I would not purchase anything from alibaba.com as alot of their traders are scam artists. A Nikon D90 for that price is too good to be true so you are right to be cautious and ask here first before you part with any money.
Below is an extract from a person who had been ripped off by alibaba.com's so called traders. Also read the posters blog.
"I was recently a victim of a scam on Alibaba.com. For those that don't know what Alibaba.com is; it's a business to business network that allows business to connect and trade their goods. Well, there is a certain verification that a company can get which is called a "Trust Pass." This basically states that they are a trusted member."
"So what is the problem? These "Trust Pass" members are ripping people off left and right, and Alibaba.com is doing nothing to stop it. If you are ripped off they take no responsibility whatsoever for it. It is so frustrating and I really don't know what to do, other than get peoples stories out there. Please check this blog to see what I mean: Alibaba.com ripoff blog.
What can we do about it? There have been talk about filing a class action suit. To be honest with you I don't know how to do it. People are contacting me daily about being ripped off by these "Trust Pass" members. Surely, something can be done about this situation. If you have been ripped off there please do leave a message there. I am getting enough people together that surely we can come together and get something done about the situation."
I hope this clears up a few points for you.
Regards.
The CRH error message means that the lock tab on your memory card is in the locked position. The purpose for the lock switch is to allow you to set your SD card so that you cannot accidently erase your valuable pictures. Remove your SD flash memory card from the camera and hold it in your hand with the label toward you and the angled corner to the upper right. Look on the left edge of the card and you will see a very small slider switch. Make sure the switch is in the fully up position then reinsert it in the D90. If the camera is not generating a false error, your camera should work correctly.
Nikon D90... | Answered on Oct 11, 2014
Your problem is that you are not using a suitable memory card for the D90. 2Gb SD cards have read/write speeds that are much too slow to work with quality DSLR's. Let me explain. When you take a picture with the D90, the data generated first goes into a small capacity buffer memory. The purpose of the buffer is to act as a conduit to your SD memory card and retain picture data until all of the data is safely written to the SD card. If your SD card can accept data as quickly as the buffer can pass it to the SD card, there is no problem. But, If the SD card is not capable of accepting the data quickly enough, the buffer will start to fill up since data is coming in faster than it is going out. If you take pictures in quick succession with a slow SD card or if you shoot video with a slow SD card, the buffer will overflow; i.e., fill to its capacity and become incapable of accepting more data until its capacity returns as the SD card accepts the data. During that time, the camera will prevent you from taking any more still photographs. You will push the shutter release and nothing will happen. If you are shooting video, the camera will continue to work, but the sound will loose sync with the picture.
For your D90 to function properly under all conditions, you must have an SDHC card that is rated at 45Mbs or faster. When I first bought my D90 several years back, 35Mbs was the fastest card made and I had the problems I described to you above. When Sandisk brought out the Sandisk Pro card with a 45Mbs speed my problems melted away. I should also ad that 2Gb is much too low of a capacity for the D90. It will fill up very quickly if you shoot Raw or fine quality jpeg files. You need a minimum of 8Gb.
Nikon D90... | Answered on Oct 10, 2014
If you're in one of the PSAM modes then don't pop up the flash.
You can use the Auto-No-Flash mode by turning the mode dial to the position after the green Auto mode (a lighting bolt in a circle with a slash through it).
Nikon D90... | Answered on Oct 08, 2014
I feel for you. exactly the same happened to me but i was looking to upgrade lens so i used it as an excuse.the piece is called a bayonet. what lens is it, is it the kit lens. my lens was unfixable so  am afraid as the mount is plastic the whole lens is a right off, if it was a metal mount it would be worth fixing. sorry
Nikon D90... | Answered on Oct 03, 2014
Nikon D90 Digital Camera with 18-105mm lens Logo
464 questions posted
Top Nikon Cameras Experts
Ric Donato
pictureman4u
Geoff Hone
Are you a Nikon Camera Expert? Answer questions, earn points and help others
View Most Popular
D Nikon
  • D Nikon
Most Popular Question
not autofocus
  • Cameras
