There could be a few reasons why the stitches on your New Home 910 sewing machine are tight and the fabric is not feeding forward properly. Here are a few things you can try:
Check the tension: Make sure that the tension on your sewing machine is properly adjusted. The tension controls how tightly the thread is pulled through the fabric. If the tension is too loose, the stitches will be too loose, and if it is too tight, the stitches will be too tight. You can refer to your sewing machine manual or a tension chart to help you adjust the tension properly.
Check the needle: Make sure that you are using the correct needle size and type for the fabric you are sewing. Using the wrong needle can cause the stitches to be too tight or too loose, or it can cause the fabric to bunch or pucker.
Clean and oil the machine: Make sure that you are regularly cleaning and oiling your sewing machine to keep it in good working order. Debris or lint can build up in the machine and cause problems with the stitching.
Check the feed dogs: The feed dogs are the small teeth that move the fabric through the machine as you sew. Make sure that they are not clogged or damaged, and that they are properly aligned with the needle.
Seek professional help: If you have tried these steps and are still experiencing problems with your sewing machine, it may be necessary to seek the help of a professional. A qualified sewing machine technician will be able to diagnose and repair any issues with your machine.
it sounds like the feed dogs are not working, can you see them in the needle plate area? you should be able to see them and feel them with your finger. what is the name and model of the sewing machine?
change the needle--make sure it's the right needle for the fabric being sewed rethread the machine top using every thread guide check to make sure the bobbin is not over wound, make sure the bobbin is not warped, & that the bobbin is inserted correctly into the machine make sure the thread has not come off the thread take up lever it's also possible that the machine is out of time
it sounds like you have a problem with the feed dogs, in the needle plate area check to see if the feed dogs are in the up position, you should be able to feel them with your finger & if not then the machine needs to be serviced
Sue, try this checklist- are you using 60W or #60 bobbin thread? Is your needle fresh (sharp)? Are you using a good stabilizer that's appropriate for your fabric? Is your fabric tight (not too tight) in your hoop? If all the answers are yes, your tension on your machine may be off or you may have bobbin issues. Also, if your machine uses a round shank needle, check to make sure it's in the right position. Maybe this will help
I found out that by spraying silicone on each side of joins that it made the fabric glide through the feed dog real easy, this really works well, make sure that the silicone is suitable for sewing machines.
