20 Most Recent Singer Featherweight 132Q Mechanical Sewing Machine Questions & Answers
5answers
Hi, I need a manual for a Singer Model 100
I need a manual for the Featherweight, too.
1/29/2022 10:49:06 AM • Singer... • Answered on Jan 29, 2022
I cleaned the feed dogs and shuttle area on my Singer 132Q this morning and replaced all pieces according to my manual. I started sewing and the needle ran into a stick pin in the garment. It broke th
The easiest thing is to take it for service. It's very likely that even if you were able to free up the machine that it has been knocked out of time. Very important to avoid sewing over pins.
12/28/2017 7:05:17 PM • Singer... • Answered on Dec 28, 2017
2answers
How to time my machine
only a sewing machine repair shop has the tools & repair manual to retime a sewing machine
8/17/2015 10:01:46 PM • Singer... • Answered on Aug 17, 2015
How to set to zigzag stitch
Page 17 of the manual shows the settings for a zig-zag stitch. If you don't have the manual, you can download here: http://www.singerco.com/uploads/download/1288_132.pdf
4/26/2015 7:26:59 PM • Singer... • Answered on Apr 26, 2015
I cannot find the sewing machine light on singer featherweight model 100
I believe I just answered this question; download the user's manual at the Singer site, and on page 28 (I believe) it shows you where it is and how to replace it. Apparently, you can use any sewing machine bulb, but not over 15 watts.
11/29/2014 4:40:11 PM • Singer... • Answered on Nov 29, 2014
WHERE IS THE LIGHT ON MODEL 100 SINGER FEATHERWEIGHT
Please download the user's manual from the Singer site; it is a free download. On page 28, it tells you where it is and how to replace it.
11/29/2014 4:33:16 PM • Singer... • Answered on Nov 29, 2014
K7356858 Singer Featherweight
I found it listed on sewing machine outlet for $149.00. Singer 132 Featherweight 20 Stitch Compact Lightweight 3 4 Size Sewing... Hope that helps you.
8/27/2014 4:14:12 AM • Singer... • Answered on Aug 27, 2014
Where can i get a singer sewing machine 132q manual?
You can order a pdf download at the following site: Instruction Manual Singer 132Q Featherweight
8/4/2014 5:01:04 AM • Singer... • Answered on Aug 04, 2014
I need an instruction manual for a singer featherlight 180
Try Singer's web site.
7/20/2014 5:34:24 AM • Singer... • Answered on Jul 20, 2014
How to adjust the tension?
here is a link for a free manual, the information you need should be in it http://www.singerco.com/uploads/download/1288_132.pdf
6/5/2014 1:49:06 PM • Singer... • Answered on Jun 05, 2014
How do I adjust my bobbin tension
The problem probably comes from not threading the top of the machine correctly. Take a look here: http://www.picturetrail.com/sfx/album/view/22521551 especially at the last pair of photos. The blue tangled thread is on the top of the machine, the red thread in the bobbin. Set the top tension to about 3-4, and rethread from scratch, this time with the presser foot raised. This causes the tension disks to open so the thread can get between them When you drop the presser foot to sew, the top thread is then tensioned and won't make loopy messes.
4/30/2014 12:54:08 AM • Singer... • Answered on Apr 30, 2014
Material is not being fed thru
Check for lint in feed teeth
4/22/2014 10:54:59 AM • Singer... • Answered on Apr 22, 2014
Needle will not pick up the bobbin thread.
Could the needle be inserted incorrectly? Typically, the flat of the needle shank goes to the back of the machine. Are the needles the correct type for your machine?
3/28/2014 5:30:03 PM • Singer... • Answered on Mar 28, 2014
Singer MON AMI CLAIRE Sewing Machine User Manual
Right here. You will need to be able to download PDF documents. Does anyone have the Singer Featherweight 132Q Manual that you could...
3/10/2014 11:58:03 PM • Singer... • Answered on Mar 10, 2014
Not pulling the materioal thru
Look at your manual, or look around the base of the machine. There is an option to drop the feed dogs. This stops the pulling through action of the machine. You just have to flip a switch. This is normally what is happening.
1/31/2014 9:00:57 AM • Singer... • Answered on Jan 31, 2014
Singer Featherweight 132Q Mechanical Sewing Machine Logo
119 questions posted
Top Singer Sewing Machines Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Singer Sewing Machines
Most Popular Question
adjust tension
  • Sewing Machines
