20 Most Recent Necchi 3537 Mechanical Sewing Machine Questions & Answers
Try this:
http://translate.google.co.in/translate?hl=en&sl=it&tl=en&u=http%3A%2F%2Fviewer.zoho.com%2Fdocs%2FeddHdd
i think this will surely help you!
ask for a PDF manual...by mailing them at
info@necchi.it
or call at:
1800-525-9987
Necchi 3537... | Answered on Sep 18, 2018
Usually pedals possess a variable rheostat controller that react with the action of your foot. If it fails to function normally, it suggests that a short circuit has occurred. Generally, that means an internal wire or contact opens up and stops all further activity as you mentioned. The best bet is to take the machine to your local sewing machine dealer for repairs.
Necchi 3537... | Answered on Jan 13, 2018
A lot of machines have a speed control, either on the machine or the foot control. I looked thru the manual and did not find anything about speed control. Look under the foot control for a screw that may have a + and - . Otherwise, you may want to take it back to see if service can adjust it for you.
Necchi 3537... | Answered on Jan 10, 2018
does anyb ody have a manual i can download
Necchi 3537... | Answered on Feb 05, 2017
Here's what the manual says:
Before sewing, fit the button-hold foot to the machine (long white plastic thing with red, ruler like markings).
Select the pattern selector dial that is solid green on the left hand side. Set the dial to "1" position. Sew the left side and raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "2" position. Sew 5-6 stitches and raise the needle.
Select the pattern selector dial that is solid green on the right hand side. Set the dial to "3" position. Sew the right side. Raise the needle.
Select the pattern selector dial that is solid green on the top and bottom. Set the dial to "4" position. Sew 5-6 stitches and raise the needle.
Hope that helps...
Necchi 3537... | Answered on Nov 09, 2014
There are a number of things that could cause this.
Needle installed with flat in the wrong direction.
Excessive thread tension,top or bottom.
Lack of lubrication. If the machine can do anything more than a straight stitch the mechanism can gum up and not move the needle correctly.
Here is a link to threading directions.
Necchi 3537 Sewing Machine Threading Diagram
Necchi 3537... | Answered on Aug 03, 2014
there are no free manual for a necchi sewing machine that I know of
but incase you want to buy one here is a link for one that's only a little over $10.00 + shipping.
Necchi 3537 Instruction Manual
or you can try the allyn international co, that used to sell them, here is a email address
Allyn International ----phone--303-825-5200
Necchi 3537... | Answered on Jul 18, 2014
There won't be many people on here with experience of that drier (in my opinion!), but here is a forum where you are more likely to get the help you need: Coin Laundry Forums Planet Laundry
Necchi 3537... | Answered on May 14, 2014
Necchi 3537 Mechanical Sewing Machine Logo
150 questions posted
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Necchi Sewing Machines
Most Popular Question
anyone new home sewing machine model 537
  • Sewing Machines
