20 Most Recent Necchi 3101 Mechanical Sewing Machine Questions & Answers
Sometimes the spool pin is in with the accessories and not on the machine.
Still no pin? Try these folks - http://www.allynint.com/
Necchi 3101... | Answered on Jul 28, 2018
See that button/knob at the lower right hand-side of the front? The center is a button you depress and hold to reverse. Good luck!
Necchi 3101... | Answered on Jul 26, 2018
hi there,
well, common problem when you didn't acquired right set up of tension and clean feed dog,bobbins,shuttle race.on figure right bobbins winding.d329aa1.jpgset up counter clokwise thread rotation, set dial tension on #3 to #4, dial stich to # 8 to #12
only on cotton fabrics,others fabrics such as silk..etc,gradually adjust tension fine the smoothest adjustment,
on fig,thread looping top side threading50302ec.jpg follow threading so you can have fine sewing.also clean under bobbins from chips fabric and dust.have a nice day,don't forget to rate my fix,ythanks a lot
Necchi 3101... | Answered on Apr 05, 2018
The thread will be threaded in a clockwise direction on the tension control. Pull the thread until there is a tension on the spring. There will be a catch on the thread that you will notice this. Now, thread the machine in the same way that is normal. It should work. Make sure you start your tension at four to test how it is doing. From there make slight changes in tension. Don't worry about the very tiny bend in the wire at the very end. It is only for weight and to keep your thread from catching and getting broken.
Necchi 3101... | Answered on Dec 21, 2017
I have an ALCO 2200. Luckily I have the manual. If some one need the manual, I can photocopy and send it to you, if you do not mind paying the postage. :)
Necchi 3101... | Answered on Sep 10, 2017
Actually, $10 for a manual is probably a valuable investment. It will not only help you with threading & winding the bobbin but also with maintenance and care of your machine and as well as how to use your machine. Similar brand machines thread and wind the bobbin in the same manner. So, even finding a similar Necchi and the bobbin winding method should be helpful.
Necchi bobbin wind Google Search
Necchi 3101... | Answered on Oct 17, 2016
sounds like the contact in the foot peddle has failed try a new peddle
Necchi 3101... | Answered on Mar 07, 2016
Search the internet for:
Manufacturer + Model + the word "Manual"
Necchi 3101... | Answered on Nov 10, 2015
the hand wheel is a 2 part device hold the outer wheel and release the inner part by turning it toward you . wen done winding bobbin retighten the wheels together .
Necchi 3101... | Answered on Aug 26, 2015
Check the bobbin tension. Good videos on Pinterest.com if you need help doing it.
Necchi 3101... | Answered on Nov 19, 2014
try these 2 links for a manual, it should have the information in it you need. you can choose which place to buy the manual from.
Necchi 3101 FA 3102 FB Instruction Manual
Necchi 3101FA Parts
Necchi 3101... | Answered on Jul 18, 2014
if you have e-mail I can scan and send you the diagram.
Necchi 3101... | Answered on Feb 09, 2014
Necchi 3101 Mechanical Sewing Machine Logo
125 questions posted
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Necchi Sewing Machines
Most Popular Question
size sewing machine
  • Sewing Machines
