20 Most Recent Necchi 6015 Mechanical Sewing Machine Questions & Answers
Increase the upper thread tension, or loosen the bobbin tension to balance them. Put in a new needle too. Check that the needle is in correctly.
Necchi 6015... | Answered on Nov 19, 2014
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
down?
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
http://www.sewingpartsonline.com/instruction-manual-necchi-6015.aspx
Necchi 6015... | Answered on May 28, 2014
check youtube for video's on winding a bobbin
or for a manual check these sites
sew4less.com
sewusa.com
sewvacdoctor.com
Necchi 6015... | Answered on Apr 17, 2012
The whinning noise could be a slipping belt which you need to check, you should be able to take the side off to see
Necchi 6015... | Answered on Sep 14, 2011
Reduce the bobbin thread tension. It is done by loosening the little screw on the bobbin case. It is a sensitive adjustment so turn about 1/8 of a turn at a time.
Necchi 6015... | Answered on Mar 31, 2011
Hello jone...... please rewrite your question one more time starting fresh with the brand, model number and exactly what is wrong with your machine. We truly do want to help you but we need all of that info. in one place. Thanks. Joe
Necchi 6015... | Answered on Dec 24, 2010
Go to http://allynint.com/
Get the phone number off the web and call them, they have what you need.
If you speak to Dorothy, or Bob Coen, tell them Merry Christmas from Ellen in Arizona. Merry Christmas to you too,
Do a goggle search to find a Sew & Vac near you.
Necchi 6015... | Answered on Dec 18, 2010
Necchi 6015 Mechanical Sewing Machine Logo
44 questions posted
Top Necchi Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Necchi Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Necchi Sewing Machines
Most Popular Question
bobbin thread straight across
  • Sewing Machines
