Machine goes out of balance even with a light load wash time restarts, drun slams into cabinet
SOURCE: out of balance during wash
Ok you need to check your machine is level- if not adjust feet. You aslo need to check the Bias spring is still attached if not get a new one or re-attach it. The Bias spring is a little spring that connects from the top of the front left suspention rod to the top of the plastic bowl cover (this spring is meant to help stop it going out of balance so easy. Cheers
SOURCE: washing machine not spinning
Here is a tip that will help you with that...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
SOURCE: GWL 11 will not pump
1 check the vacuum hose from the float switch to electronics boards to see if its cracked and has air leaks. you should be getting fault lights if the pump is jammed,blocked or is faulty and not working.
SOURCE: Fisher paykel aquasmart top loader washing
Hi - you have possibly some restrictions in/around your smart pump unit, inside is a flapper valve suppose to control flow in both directions, often this gets the rough treatments.
Be careful if you wish to have a nosy its located beneath the smart agitator.
SOURCE: Every wash, the machine on rinse/spin cycle, makes
Hi Sandra, I'll have a look into this. This machine isn't my usual brand, so I'll have to see what I can find out for you. I'll get back to you by tomorrow :) Joe
