20 Most Recent Fisher and Paykel Fisher Paykel Intuitive Eco Washer IWL15 Questions & Answers
136. (10001000) Motor Stall
The Motor Control Module has been unable to start the motor. Possible causes of this fault
are: Faulty motor harness, faulty or jammed motor, seized bearings or seals, faulty Motor
Control Module, faulty Rotor Position Sensor or harness.
Primary Source: Wiring.
Action: Measure/check the motor harness, connectors and motor for
discontinuity. This can be done by taking a resistance measurement
between phases of the motor harness at the Motor Control Module
end. Nominal resistance should be around 32Ohms.
Secondary Source: Motor.
Action: 1) Check free rotation of the agitator and basket by rotating by hand.
Bearings and seals may be seized.
2) Check the Rotor Position Sensor and associated harness for
water, mechanical damage or corrosion.
Tertiary Source: Motor Control Module.
Action: If the primary and secondary checks pass inspection, then replace
the Motor Control Module.
Fisher and... | Answered on May 05, 2019
I can talk you througt this in live chat, but you'd need to get a F&P Bearing replacement toolkit and seals and bearings and a new agitator shaft. cheers
Fisher and... | Answered on Feb 25, 2019
Hi just read your posting.Error code 43 is called OUT OF BALANCE SWITCH ERROR.This means either your switch is faulty or your your control module is faulty.95 % of the time it is your switch which is located under the control module which is under the top panel.If you want I can guide you step by step in the replacement of this switch.Please reply on how you would like to proceed and I will help you as much as I can.Looking forward to your reply.
Fisher and... | Answered on Dec 12, 2018
I also got Error Code 37 at the end of a wash with the machine full of suds. I used the other information listed under this problem to establish that the pump was blocked, (no amount of hand-turning loosened the fan). After unplugging the machine from the wall, I removed the pump easily by unplugging the power and earth from the pump, pressed in a clip on the side of the pump to allow the whole pump to rotate and then pull out, (a bayonet type fitting). From where the pump came out from was a small piece of cloth and other gunk! I refitted the pump and reconnected the power and earth. The machine is now working happily again.
Fisher and... | Answered on Dec 02, 2018
check drain pump is not blocked or faulty
Fisher and... | Answered on Nov 29, 2018
if it keeps filling until it floods the it has afaulty transducing which is locatedin the mainboard which will have to be replace
Fisher and... | Answered on Apr 21, 2018
repace the thermostat
pump block error remove pump check foranything blocking or jamming it it that fails replace pump
this code indicates a faulty main board
top loader yes remove cap off top of agitator there is a plastic wing nut at the bottom undo anticlockwise and agitator canbe removed and replacement
faulty cold water solenoid or sensor
this is a faulty transducer which is located on the main board unfortunatley you will need to replace the whole thing
its suppsed to as long as it even
blocke filter on cold solenoid or faulty solenoid
I BELIEVE THAT IS A ROTOR SENSOR ERROR
REPLACE THE ROTOR SENSOR
Fisher and... | Answered on Mar 08, 2018
If you wired the pump directly with a lead and 230V supply and it works ok, then doesn't work when powered by the control board, I would say that there is a problem with the control board not supplying a full 230V to the pump.
Fisher and... | Answered on Dec 08, 2017
rotory postion sensor is faulty
Fisher and... | Answered on Nov 20, 2017
one of the computer boards is faulty,no way to tell which try one and if not fixed try the other one
Washing Machines Logo
557 questions posted
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Washing Machines
Most Popular Question
intuitive eco washing machine says power
  • Washing Machines
