20 Most Recent
General Electric WCVH6800J Front Load Washer Questions & Answers
Have a new ge WCVH6800 front load washer. Power
Hello there and welcome to fixya
You may want to try unplugging the machine for a minimum of 2 hours to let the internal cpu to reset itself then plug it back in then press the mode button then try to lock the door and it should be ok after that ok please inform me how this goes there is more we can do for this ok
Best regards Michael
Why does myAmana 7300 front load washer door not open?
If the cycle is done, sounds like your door switch could be sticky,. If there is water in it, it will have to pump out the water to a certain level before the door will open, removal of the water would be your issue or the pressure level switch thinks is not drained out, in which would be a pressure switch.
General Electric WCVH6800J gasket broken
not to hard to change first you need to get it out there is a spring holding it grab the bottom side of the gasket and you will feel the spring not to hard to doit take a picture or samething to remember how to put it back in make sure the drane hole goes on the bottom.
