20 Most Recent Fisher and Paykel GWL11 Top Load Washer Questions & Answers
Hi, I'm Neninenotek, people usually call me Nenotek. There's not so much to say about me really, just like an ordinary good girl.. I drive a Honda Supra. Its my father car that he gave to me. I try to find any club and party because in every moment that i met i feel alive. Feel Free To Know Me, send me message. http://yakinqq.info/
Fisher and... | Answered 3 days ago
If you cannot see the water leaking from the inlet valves, check the seal just above the water pump located directly under the drum. I am in the midst of awaiting parts to fix this very thing on my FP GWL11. This leak is dripping water directly onto the motor, causing it to trip the circuit breaker during drain/spin cycles.
Note... I have also had to have the inlet valve assembly replaced as well as it was not opening to allow cold water to mix with the hot.
Hope this helps.
Fisher and... | Answered on Oct 01, 2019
It beeps to tell you there is an error. While it is beeping & before pressing any buttons, read the error code & write it down. The error code is the lights along the top row. Count from left to right and make a note of exactly which lights are on and which are off. There are 8 lights, you need to say exactly which number light is on. Post the result back here and someone will tell you what that error code means.
Fisher and... | Answered on Jul 11, 2019
I had the same problem.... It would stop on the rinse cycle and beep.  Check to make sure you can hear the water pump running or if you can just hear an electrical hum and then it quits, it may be a problem with the water pump.The water pump can be accessed by removing the tub, reach down the center of the agitator and remove plastic bolt, remove the stailess steel tub and then remove the plastic oval shaped cover at the bottom of the main tub to access the pump impellor.  Make sure the impellor turns freely, if it does not you may have a problem with the pump motor.  We had a gold chain go missing and it showed up wrapped around the pump shaft causing it to bind at times.  It took me two tries to fix it but now it runs 100%.
Fisher and... | Answered on Nov 10, 2018
probably a faulty cold water solenoid
Fisher and... | Answered on Sep 22, 2018
The fuse is built onto the control board. It is not designed to be replaced. My 3 year old machine lost the water pump and blew the fuse. About $375 to fix. I am buying the new pump and will attempt to replace the fuse on the board. I hope there are no other bad components.
Fisher and... | Answered on Jun 28, 2018
under the top of the machine on the right there is a reed switch which is actic=vated by a magnet in the lid remove the two bungs and screws so you can lift the top up a bit and you will see it there one screw to remove it if its corroded or swollen its faulty either repace it or as a easy fix cut both wires off it and join them together and tape up, this should do it
Fisher and... | Answered on Apr 21, 2018
check out the drain pump as it is linked directly to the main board any burning smell or discolouration of the copper windings replace it
not alot u can do but replace the board
ok if when you push pause the water stops its not your solenoid but the transducer which is built into your main computer board which you will need to replace
this usually means warm wash is selected but only cold tap is on try turning hot tap on even for a cold wash
manual say display unit so try thst first,most repairs have plenty of second hand ones lying around
first thing to look at is the sensor either faulty or corroded connection block if good or a new one doesnt fix it then most likely the main computerboard fault
no not thst i know of but its always been a problem with them over tha last 20 years
its really important the R.P.S you replaced is correctly fitted so double check it,also the connecting block if corroded in anyway will cause the faulty its easy to see the bluey color of corrosion, i have struck faulty new sensors beforebut not all thst common if you are really sure all that is 100% then it can only be the wiring loom
with power to machine but all lights off press temp water down button and power button at the same time machine will give two short beeps release then pree spin speed up button three times the lights that are now on is you fault code
one of two things shorted out drain pump,or main board is blown, try pump first
the switch is faulty replace the switch
this is a faulty out of balance switch which is located under the main computer module once replace sgould be ll good
Fisher and Paykel GWL11 Top Load Washer Logo
1,825 questions posted
Top Fisher and Paykel Washing Machines Experts
Archie Ferrarini
Archie Ferrarini
Gerry Harvey
Gerry Harvey
jimorris77
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Fisher and Paykel Washing Machines
Most Popular Question
washing machine not draining finishing
  • Washing Machines
