20 Most Recent Whirlpool Cabrio WTW6600SBT Top Load Washer Questions & Answers
Solved the unbalanced problem - open the top of the machine (press in with a flat putty knife about 3" in on the front on each side while lifting up as there are 2- 1" wide catches). Once both sides are unlatched, raise the lid then slightly lift the rear of the lid so that it fits into the curved part at the top of the hinges then open all the way - tape the lid to the top so it doesn't flap about and scotch the lid to keep it from falling back down on you. Now, look around - see all that rust?  The rust has fallen into and gotten underneath one or more of the 4 white plastic suspension "ball joints" which have probably totally dried out by now from their factory grease because of the water, bleach, and rust particles.  Having someone help you, simply lift up on one of the 4 corner suspension rods - gravity and weight is all that holds them down. The white ball will lift out of the socket and still be attached to the rod. Clean out the rust, lightly sand the "socket" with emery cloth, then slop in a fingerful of grease. I used automotive wheel bearing grease with graphite in it. Also scrub off all embedded rust on the white plastic ball. Lower that corner back into the newly cleaned and greased socket and repeat for the other 3 corners. Now when you move the tub around notice how the balls pivot in their sockets like they are supposed to. When they were dry and rusty they wouldn't move enough to allow the tub to twist like it should so it slammed around.  Now, shake your head in disgust that after only 2 years there is so much rust that you wonder if it will make it another year before falling apart, close the lid, and try another load.  That totally solved my off-balance problem where even a single handkerchief would give the UL error. It is still a finicky machine, but at least once again works like it did when new.
Whirlpool Cabrio... | Answered on Jan 04, 2019
YOU CAN WHAT YOU HAVE TO DO IS TAKE THE 2 WIRES FOR THE SWITCH AND SPLICE THEM TOGETHER BY-PASSING THE SWITCH MAKE SURE POWER IS OFF BEFOR WORKING ON ,IF ITS A PRESSURE SWITCH THAT WORKS BY THE LID BEING CLOSED TRY TAPEING OR LOCKING IT DOWN THIS MIGHT BE EASYER
Whirlpool Cabrio... | Answered on Sep 29, 2018
Thank for your writting! It is easy to understand and detailed. I feel it is interesting, I hope you continue to have such good posts.
color switch
Color Switch
Whirlpool Cabrio... | Answered on Sep 27, 2018
I have started a petition to be sent to the CEO of Whirlpool Corp., Jeff Fettit.
Follow the link, and please sign it! The more the better! Spread the word!
You may also copy and post it to any other groups/discussions about this problem.
http://www.petitiononline.com/cabrio08/petition.html
Thank you!!!
Whirlpool Cabrio... | Answered on Sep 26, 2018
First off I hope you have a Sears unit and second you did not pay a penny. Your F 1 error is a Primary control failure. Part W10104830 and one other do F1 and a oL code.
If you own a Sears machine you qualify for a recall under sf26-779B.
There is two parts to this call the board and a washplate
MCU part # W10201186
Washplate # W10077050
Recall will need your name and phone number and the machine model and serial number.
If you meet all of these conditions to the letter call Sears Recall at 1-800-659-7026
Whirlpool Cabrio... | Answered on Aug 05, 2018
Rent to own or rent to rent washers are are fixed or replaced free by the rent to own company. Call em and tell them to send out another machine or a repair guy.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Whirlpool Cabrio... | Answered on Aug 04, 2018
See the following Whirlpool Service Manual for the Cabrio.
This should help.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Whirlpool Cabrio... | Answered on Jul 22, 2018
how do i reset a whirlpool cabrio wtw5500xw2
Whirlpool Cabrio... | Answered on Jun 01, 2018
theer have been no reported problem with using the DREFT baby soap in the HE made machine,
Whirlpool Cabrio... | Answered on Apr 22, 2018
LT is not an error.
Perhaps LF?
CLICK HERE for the error code list.
Thanks!!
Whirlpool Cabrio... | Answered on Mar 25, 2018
Spring:
Thank you for your review.
We would like to inquire further about your review with you. Please respond back to this email address, Whirlpool_Reviews@Whirlpool.com, with your name, phone number, street address, zip code, model & serial number, and date of purchase on the appliance.
We look forward to your reply.
Thank you,
Whirlpool® Social Media Relations
Whirlpool Cabrio... | Answered on Mar 09, 2018
The F54 code is a motor control overcurrent error. If you keep seeing this error then you ned to callin a service man to have the system looked at.
Whirlpool Cabrio... | Answered on Feb 21, 2018
Sounds like you have a transmission leak.The bearing wouldn't throw that much grease.
Whirlpool Cabrio... | Answered on Feb 03, 2018
I would call the Whirlpool machine repair person for a quote as only an experienced engineer will know what the problem is eric
Whirlpool Cabrio... | Answered on Jan 17, 2018
it sounds like the water pump is not emptying properly, blow down the water outlet pipe to see if is clear if not go to the water pump and clean it out there is probably a button , paper clip or other debris preventing it from doing its job eric
Whirlpool Cabrio... | Answered on Dec 26, 2017
Apparently it's a common fault (among others) with this brand/model of washer; as Whirlpool has dedicated a page to it.
How to clean the interior of your washer to remove odors
Whirlpool Cabrio... | Answered on Dec 19, 2017
Sounds like a blockage between drum and pump or outlet water hose to drain,or the pump needs replaced
Whirlpool Cabrio... | Answered on Dec 12, 2017
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
3,787 questions posted
Sal De
Marvin
Marvin
Justin Duby
Justin Duby
View Most Popular
Cabrio Whirlpool
  • Cabrio Whirlpool
Most Popular Question
cloths wrinkled
  • Washing Machines
