There is a test button on them if icemaker is in botton draw freezer section button is located on the bottom front on the icemaker its a small square button. If its the icemaker in frig section button on the right side on icemaker it is rectangular rubber coated hold about 10sec
You need to factory reset! from off, press power and volume+ buttons together until reset screen comes up, then move using volume and select using power buttons!
1999-2003 Reset Button location The switch is located inside the jack storage compartment found at the right rear corner of the vehicle. Remove the cover and it is behind the thin "foam" covering inside the compartment towards the rear of the vehicle.
I was also looking for that, but i couldn't find it. But i got one solution to format Nokia 5800 it doesn't work for security code. To format or hard reset nokia 5800 press 'green key, red key and camera botton. After pressing these three botton, press the power which is located at the top. When it shake release only the power botton not the green, red and camera botton. It will start up your phone and after sometime it will display country botton and now you can release the keys. Thats it. This is call Hard Reset.
push the reset botton on the box in the tree, on the back if the remote there is a reset bottom, push the reset botton on the tree until the light start to blick then push the reset botton on the remote, thats what i did to mine
I've successfully reset the plantronics explorer 210 by holding the big button on the outside (by the flashing light) down for 5-10 seconds. I wait until the light starts flashing red/blue instead of just blue.
ok.... i see thtt ur prob is the same as mine. so here is the solution for it.... in ur pda on the left side there will be two buttons a camera and a voice recorder ok... just hold those two buttons at the same time and stick ur stylus in the soft reset hole.. located at the bottom of ur pda... and keep those buttons and the soft rest botton pressd ultil u see the options on ur screen 1.Enable KITL: NO 2.Format Registry Hive: YES 3. Format Storage: YES
yes and no can be nevigated by the two buttons camera and voice recordr .. once these optinons are set press the mail botton.... and kazaaammmm ur pda is blank dnt worry it will reset or u can turn it off if it dosnt respond for 5 mins... and ur problem is solved the phone is reset right from the beggining and u can install all ur programns again!!!
