20 Most Recent Siemens SX66 Questions & Answers
Hello Sambicho.
The a1b2c3 may be the 'password reset' code after which you must enter YOUR original password, which it hopefully still has stored in it's memory.
Otherwise the 'someone' may have changed the user password.
Hope this is helpful.
FYI: passwords are case-sensitive.
Siemens SX66 | Answered on Oct 11, 2017
Time for anew phone.
Siemens SX66 | Answered on Jun 26, 2017
it doesn't jump in app sry sry sry
Siemens SX66 | Answered on Aug 19, 2013
Hard Reset Hold down the Power button (Top Right corner) and at the same time put your Stylus pen in the hole where it says “Reset” (Lower Left corner).
Hard Reset will delete all data you have put on the device, Programs, Settings, Mail, SMS, MMS, etc., so be careful and make a backup before doing this.
After a hard reset, you will have a complete clean new install of Windows Mobile on your device.
Things that are not deleted
  • Data on \Storage Card
  • Data in \Storage folder
Siemens SX66 | Answered on Feb 17, 2012
is the button near the reset hole? possibly the button is somehow pressing the reset switch, possibly stuck somehow. Other than that try a hard reset, instructions below.
Soft Reset
Put your stylus in the hole in the lower left corner where it says “Reset” Soft Reset will reboot your device just like when you reboot your PC. No data will be lost, under normal circumstances that is.
Hard Reset
Siemens SX66 | Answered on Jan 01, 2012
You can get the unlock code here http://www.superunlockcodes.com/unlock-your-phone/rs12wp2/ at low cost and also get the unlock instructions in the same site.....
Siemens SX66 | Answered on Apr 13, 2011
Hello, Did my solution fix your SX66 problem?
Siemens SX66 | Answered on Mar 05, 2011
Go to system/screen/align. Realign
Siemens SX66 | Answered on Dec 03, 2009
This could be an internal problem on the device, cause of instant shock cause of dropping it. You better try to remove the battery for a while to reset and restore the system.
If the above recommendation did not solve the issue, try to remove the memory card, if still not working try to update the firmware of your unit.
Let me know here again for the update.
micro
Siemens SX66 | Answered on Jul 19, 2009
You have a problem I would love to have. I can't get any. At any rate. Go to settings and change refresh rate to timed.
Siemens SX66 | Answered on Jul 11, 2009
Yup....and I sell em. Love em. Bobzmailroom@yahoo.com
Every phone ships with a factory reset option. Check out the settings for Factory Reset. This will remove all data on the mobile and will revert it back to the settings as when it was when bought.
Siemens SX66 | Answered on Jun 24, 2009
If that is the only card that does that, reformat the card on your pc.
Siemens SX66 | Answered on Jun 19, 2009
Reformat your SD card. If this is helpful, please post as such. TY
Siemens SX66 | Answered on Feb 05, 2009
Network signal strength is not based on your phone. It is based on the network. Poor sigal is their problem, Call them. If this rates as helpful, please post as such.TY
The first thing to do is make sure that the wireless router allows for the same Network Autentication. Depending on your wireless router you might have to check your user manual, but the trick here is to set the autentication "WPA-TKIP" on your wireless router, then set a custom key for for acces, once that is done, open the Wireless Manager by taping on the little blue anterna next to the bluetooth manager, is on the bottom right corner of your device, chek the "on" box, on the same screen tap once on the "Tools" menu, bottom left of the screen, next tap on  "Network Cards" there you should be able to see the network you want to access, if not, add the name of the network you just changed a few moments ago, if you don;t know the name of the network, go back to you'r wireless router set-up page, and change the pre-set name to something you remember, next select the "Connects to: internet" option", next tap on "Network key" tab at the bottom of the screen, set the Autentication: "WAP-PSK" and Data Encryption to  "TKIP", and finally input the custom network key you created earlier on the router set-up page.
Note: as far as I know there is a diference of the level of secitity the the 2 diferent data encryption type provide, and i think WPA is Older and most new wireless routers have WEP, or WEP 2, but if you live in a residential neiborghood and your router range is say 200 feet you only have to worry about ur immediate neigbors craking the network key using high tech sofware, to get to use ur wireless signal.
Siemens SX66 | Answered on Dec 12, 2008
Press and hold the Power Button + Reset button simultaneously and that will give you a Hard Reset.
Siemens SX66 | Answered on Dec 08, 2008
I would recommend using Pocket PC 2003 version normally. WM 5 or 6 may have significant issues with phone compatibility. If you can go back to 2003 and the phone still doesn't work there may be a hardware issue, then you need to replace or repair. Replace is usually the better option. Search ebay.com if that is what you need.
Below, instrutctions on getting ROM for PPC 2003:
Try www.xda-developers.com and ebay for ROM upgrades. There are many people who unlock these kinds of devices. I don't believe you can upgrade it to WM 5.0 or beyond, but that may be possible. Search for WM versions that include "unlocked" versions. The best bet is a newer version of PPC 2003.
The process is relatively simple. Once you have your ROM on CD or via download, You run it with your device hooked up to your PC via cable/cradle and connected via ActiveSync (3.7 or later). The warning is an improper ROM load could make your device unusable. It is a risk you have to take if you want it to make calls. Toss up: no phone Pocket PC, pocket PC phone, or shiny brick. If the XDA site has recommendations on a ROM source, they are not likely to steer you wrong. They will state emphatically, that you do not want any interruptions in the ROM upgrade process. If you have a power outage or something shuts off for any reason, you will have the shiny brick and be looking for a new device.
Siemens SX66 | Answered on Sep 19, 2008
I would recommend using Pocket PC 2003 version instead. WM 5 or 6 may have significant issues with phone compatibility. If you can go back to 2003 and the phone still doesn't work there may be a hardware issue, then you need to replace or repair. Replace is usually the better option. Search ebay.com if that is what you need.
Siemens SX66 Logo
56 questions posted
Top Siemens Computers & Internet Experts
Ekse
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Siemens Computers & Internet
Most Popular Question
siemen sx66 back light out
  • Computers & Internet
