20 Most Recent Siemens SpeedStream 4200 (13A4200001) Bridge Questions & Answers
http://192.168.254.254/brgmode.html ...or if they have the gay firmware >.> go to http://speedstream/brgmode.html then click apply....now set your router to log in with your user information with a PPOE login...if your like me and using the dlg-4500 just go to setup and do internet wizard to set up easily...then your ready to go... it can take up to 10 minutes for your router to configure so give it time..and if it doesn't seem like it's working in that time...try cycling your power then check again...and if still not working, do a hard reset (hold reset till lights alternat from green to red) to reset to factor default (do it for your router too becfause it will still be set to sign into your isp for you)
Siemens... | Answered on Jan 04, 2013
First unplug the power cable from your modem. Then press and hold the power button of your modem for at least 1 minute. Then plug in the the power cable and wait until all the lights become stable. Then you can try to go online to check.
If after this step you will not be able to go online then contact with your ISP provider.
For More information you can call at +1-877-255-3353 or visit our website http://fixsmith.com/
Siemens... | Answered on Jun 07, 2012
Hi! For the problem your describing, it seems that your problem may be faulty hardware. I've found that the router that your ISP (internet company) provides to you when they setup your internet don't tend to be the most reliable and highest quality, but Siemens is a pretty big name. One thing I would try, which Windstream may have talked you through, is resetting your router. This will reset your router and WiFi, which means the name of your WiFi will be reset, including your password.
Look on the back of the router. You will see 5 different ports back there: DSL, Reset, USB, Ethernet, AC/DC, and I/O. You're looking at the reset button. You need a pencil or something thin. Stick the pencil inside to the reset button, and continue pressing the reset button for 5-10 seconds. Your router is now reset. Now, see if your problem persists.
If your problem does persist, most likely your problem is a faulty router. In that case, I would call/contact the hardware manufacturer, Siemens, and see what they have to say.
http://www.usa.siemens.com/en/contact.htm
Hope this helps. Thanks for using FixYa.
Siemens... | Answered on Sep 06, 2011
hi you can check the internet connections at ip-details.com and check the internet speed in http://www.scanmyspeed.com/
Siemens... | Answered on Apr 07, 2011
Siemens SpeedStream 4200 (13A4200001) Bridge Logo
121 questions posted
Top Siemens Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Siemens Computers & Internet
Most Popular Question
dsl light blinking
  • Computers & Internet
