20 Most Recent Siemens SpeedStream 2624 Router (936-2624-001 kit) Questions & Answers
Welcome to Fixya.
You can find the start up instructions here.
Hope this helps.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Siemens... | Answered on Nov 22, 2010
HI,
You can try manuall setup of da router.
The Default gateway for Siemens Gigaset SE587 is 192.168.1.1. Open Internet Explorer and put the def gateway in the browser.
The default username and password for siemns router is admin.
Click on Setup Tab than Basic Setup on left hand side. Update the details as folloing-
Use – Tiscali data PPPoA Interface
PVC Selection – Tiscali data PPPoA
Authentication – Auto
User Name - Tiscali u/n
Password - Tiscali password
PPPoA Connection Mode- Always On
NAT - ON
And click on save settings. To confirm if the customer is connected, check the status of Online light – which should be green
. Alternatively click on status (On top) to check internet status to confirm connection.
Setting Up Wireless connection – Click on da wireless tab on the top.
Ensure that the Auto channel is disabled and the wireless channel is 11, wireless n/w is Enabled and mode is Mixed.
To secure the wireless connection – Click on Wireless Security option on left hand side
If you want the Security mode as WPA than select the wireless security mode, as WPA and enter WPA Shared key which would be on the base of the router. Again click on save settings.
Try connecting to the wireless network again and I m sure it should work..... lemme know if it does.
Cheers
SHADAB
Siemens... | Answered on Oct 31, 2010
you can try to google password genius
Siemens... | Answered on Sep 03, 2010
Use an Ethernet cable to connect a desktop/laptop computer to the router. Then, using the PC, you can "configure" the "wireless" capability of the router, and you can establish an SSID and a password. Then, configure your iPhone to _use_ that SSID & password to connect.
Siemens... | Answered on Mar 07, 2010
Are you trying to install the router.
You can do it manually without the CD.
Make sure that your computer is able to go online through the modem.
If your computer is able to go online through the modem
Then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Siemens... | Answered on Feb 10, 2010
Yes you can adjust signal with channel type.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then click on wireless settings and change channel type to 4 or 6 or 11 then save settings and restart router.
Try all 3 1 by 1 then check.
Let me know if you need further assistance.
Thanks for using FixYa.
Siemens... | Answered on Jan 19, 2010
You will need to check the wireless settings of the router .
Is there any computer connected to the router with the Ethernet cable?
If not then connect 1 computer to the router and open the router set up page. Once you open the router set up page, you will be able to find the wireless network key.
Use that password to connect to the wireless network
Click Here
for step by step Instructions on how to find the network key
Siemens... | Answered on Dec 23, 2009
theres a reset button on there somewhere. with the power on, hold reset till you see the router reset then unplug your modem, wait 2 minutes, plug it back in. then plug the modem into the router. then plug the router in.
Siemens... | Answered on Oct 17, 2009
1. Connect the wireless router to your computer with a LAN cable.
2. Start your browser and enter the router's configuration URL
3. Enter the router setup login and password
4. Change the admin password
5. Go to the wireless settings and change the default SSID and turn off SSID broadcast.
6. Setup encryption key the strongest is WAP2
7. For further secutity measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router.
8. Record the settings you have made and keep it in a safe place and Save the settings.
9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router.
10. Remove the LAN cable and the computers should be able to connect to the router.
Siemens... | Answered on Sep 28, 2009
I am assuming you had a different device hooked up to the modem directly before, sometimes you may need to call up time warner and let them know as some of the modems do not like to renew IP's properly.
Siemens... | Answered on Sep 09, 2009
If you dont want this router to be a DHCP, all you need is disable the DHCP function in this router. So, this router will only act as a switch and will not provide IPs to the other devices.
To disable the DHCP,you need to log on to the web interface of this router . Hope this helps
Thanks
Ranjit
Siemens... | Answered on Aug 20, 2009
  • delete the dial up connection on the internet option
  • click tools-internet options on the internet explorer - click connections tab, delete all dial up on the box, and select never dial a connection
Siemens... | Answered on Aug 12, 2009
I solved this problem, by hitting the reset button on the bottom of the modem, now I have no problems
Siemens... | Answered on Jul 29, 2009
Only way is to reset the Router to Factry settings.
Press the reset button on the bottom. But it has two modes one is just a reboot and the other is return to factory settings.a short press reboots it, if you hold it down for a few seconds until the power LED flashes between green and red, then release it, that will factory default it.Then you will be able to login.
Siemens... | Answered on May 20, 2009
you need to download java
Siemens... | Answered on Apr 02, 2009
messege me on aim for me to walk your through step by step. Copter64
Siemens... | Answered on Jan 29, 2009
Siemens SpeedStream 2624 Router (936-2624-001 kit) Logo
44 questions posted
Top Siemens Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Siemens Computers & Internet
Most Popular Question
lost password siemens gigaset se587 wlan
  • Computers & Internet
