20 Most Recent
Siemens Efficient Networks SpeedStream 2623 (SS2623) Wireless Router Questions & Answers
How can wifi password changing
connect to your wireless modem via an Ethernet cable for best result.
open internet explorer on your computer. type 192.168.1.1 (or 192.168.254.254)
you will be asked to enter username and password.
username:- administrator
Password :- admin (if nobody change previously)
then after successful login, go to wireless settings, may be there is a separate tab named "security" under wireless settings. or else find out which is the area with "encryption"
there you could see existing password, just change with 10 characters. save it. you have done.
it is recommended to go to reboot tab and to click ok for rebooting your modem. other wise just power off and switch on again after 5 seconds.
3/13/2019 5:44:15 AM •
Siemens...
Answered
on Mar 13, 2019
How can i know or change the main password for administrator. I cant access main page for Siemens Gigaset 504 AGU, because he inform me that password is invalid although on the default generally passw
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. If you are still not able to access router with above ip then you need to RESET it for that press RESET button for 10 seconds it is in back side of router then all settings defaults..Then you can access it with above method. . Then click on wireless->wireless security->WEP security there is code password note down it or enter new password then save setting s and restart router. then you can connect wireless with new password. Let me know if you need further assistance. Thanks for using FixYa
6/3/2017 2:35:22 AM •
Siemens...
Answered
on Jun 03, 2017
Gigaset 504 agu
power up your modem and connect to your computer directly with an LAN cable.
open your web browser (internet explorer)
type 192.168.254.254
and enter
you will be asking for administrator password which is normally "admin"
hope this answers your query
2/10/2015 7:20:21 PM •
Siemens...
Answered
on Feb 10, 2015
How i can reset gigaset 504 agu modem
power on your modem, and find an hardware reset button available on the unit itselt. press and hold for some seconds, you can release after all indications become ON and then off.
but ensure you have back up of your modem settings before you do this (for a safe side)
2/10/2015 7:16:42 PM •
Siemens...
Answered
on Feb 10, 2015
I want to cgange my
12/27/2014 5:40:01 PM •
Siemens...
Answered
on Dec 27, 2014
Hi there I have a gigaset 504 agu router and my
Its means that 11 people are using you're router. I would turn on WPA or WPA2 security on the router, and put a password on it, then use whats called MAC address filtering so it only allows you internet access. Also disable WPS if you can because it can be hacked easily.
11/4/2013 6:41:29 AM •
Siemens...
Answered
on Nov 04, 2013
How do i find the wep key on the 6520 router
Login using username and password->click "Wireless Security" and Select "
WEP" as the security encryption type. Set the default transmit key to "1."Type in a passphrase and click "Generate". This generates random passkeys.You can note down your network's SSID (listed on the security page) and the first WEP key.
8/31/2012 10:23:31 AM •
Siemens...
Answered
on Aug 31, 2012
