20 Most Recent ZEEPAD 7 inch Android 2.2 Tablet Questions & Answers
Can't get driver loaded for Zeepad 7 9XN
Hi code 43 can occur if the device driver fails uninstall the driver ,& install a new driver .cheers
11/5/2017 7:31:23 AM • ZEEPAD 7 inch... • Answered on Nov 05, 2017
0answers
3answers
How can I reboot my Zeepad?
Here are the some simple steps to hard reset your ZeePad 7.0:- 1.)First of all,Go to Settings -> Storage -> Factory Data Reset. 2.)Otherwise,Power of the device completely. 3.) Now,Hold down both volumes and power button simultaneously. 4.)After doing this,you should get an android on its back opened up or something. 5.)Now,Press both volumes at same time to open up a small blue text menu. 6.)Then use Vol - and Vol + to navigate the Recovery mode. 7.)Select "Factory Data Reset", press power, choose "yes" from the menu then press power again.
11/5/2016 6:05:32 PM • ZEEPAD 7 inch... • Answered on Nov 05, 2016
What file formats are recognized on a zeepad
Read your manual...audio is mp3 format & video is mp4,3gp & avi.
9/12/2015 3:45:16 PM • ZEEPAD 7 inch... • Answered on Sep 12, 2015
I forgot my pass code. What can I do?
Perform a factory reset...or hold down volumn & power buttons until the screen blinks
9/12/2015 3:42:17 PM • ZEEPAD 7 inch... • Answered on Sep 12, 2015
How do i reset the time zone to CST?
I would look in the settings and then time to change this option.
7/19/2015 10:24:17 PM • ZEEPAD 7 inch... • Answered on Jul 19, 2015
2answers
Error message
Here is a web site with a number of solutions to try and fix the error you are seeing: HOW TO Fix process com google process gapps has stopped Error Message...
7/8/2015 6:13:14 PM • ZEEPAD 7 inch... • Answered on Jul 08, 2015
Why is the screen using 62% of the battery
because it is the most important interface. When you leave the screen off, you also could leave the whole thing off. They still can't make cheap displays that does not use lots of power.
3/23/2015 3:29:56 PM • ZEEPAD 7 inch... • Answered on Mar 23, 2015
I got locked out forgot my pin how do I factory reset the tablet
Switch the tablet off. Then press the volume up button and keep it pressed while switching on the tablet. The tablet should stat in a special configuration mode. There will be a menu with the option to do a factory rest.
3/16/2015 8:08:25 AM • ZEEPAD 7 inch... • Answered on Mar 16, 2015
Change the time zone to CST - it is stuck on GMT
Go into your settings, system date & time. Ensure the Automatic date and time is checked, along with Automatic time zone. You can also make adjustments to time and date formats. Back out, and restart your tablet to see if this works. Date\time is a software function. Check to make sure you have the latest software version uploaded.
3/3/2015 4:27:20 PM • ZEEPAD 7 inch... • Answered on Mar 03, 2015
MY ZEE PAD WILL NOT CHARGE
both of my charging ports are bad , thats your problem also, we need to find a supplier for the parts so they can be fixed..
1/13/2015 11:38:07 PM • ZEEPAD 7 inch... • Answered on Jan 13, 2015
The charging port is not working on my zeepad 7.0
both of my charging ports on my zeepad are TOO LOOSE and wont make contact anymore, i need both ports so i can repair it myself, im so disapointed in the quality of the charging ports, one is a usb aanother is a skinny pin type...I really need the ports from someplace..
1/13/2015 3:52:23 AM • ZEEPAD 7 inch... • Answered on Jan 13, 2015
Forgot parren to unlock tablet
You need to factory reset! from off, press power and volume+ buttons together until reset screen comes up, then move using volume and select using power buttons!
1/1/2015 2:53:04 AM • ZEEPAD 7 inch... • Answered on Jan 01, 2015
0answers
How do I make the word "Demo", which is emblazoned across the screen, go away?
Did you do a factory reset? From off pressing power and volume + buttons together till reset screen comes up then select factory reset!
11/11/2014 2:26:29 AM • ZEEPAD 7 inch... • Answered on Nov 11, 2014
My tablet comes on but just stays there. It will not even go to the home screen
You might need to do a reset. With the power button off, hold the power button down without letting it go for about 10 seconds then the screen should show you how to do the rest to do a reset of the unit.
10/26/2014 8:53:19 PM • ZEEPAD 7 inch... • Answered on Oct 26, 2014
ZEEPAD 7 inch Android 2.2 Tablet Logo
165 questions posted
Top ZEEPAD Tablets & eReaders Experts
nexrad_chris
Ngoro
 Mikey
Mikey
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
View Most Popular
  • ZEEPAD Tablets & eReaders
Most Popular Question
reset zeepad when wont turn
  • Tablets & eReaders
