20 Most Recent SanDisk Sansa Fuze MP3 Player Questions & Answers
select them and delete them
SanDisk Sansa... | Answered on Apr 22, 2019
this happens... with mine a ton, i want to get a new one to get a fresh start so maybe it won't happen as often... but give it a rest or something and it will eventually start working. my problem is that the screen blacked out and it's not playing music.NVM O MY GOSH IT JUST STARTED WORKING. WOW. so i don't have a problem. yay. wow, is that ironic or what?
SanDisk Sansa... | Answered on Dec 09, 2016
To record a radio u have to go to the station u want and then push the bottom button on the turn pad and scroll down and find record and then u record.
SanDisk Sansa... | Answered on Dec 02, 2016
I experienced the same problem (my USB device ). try these steps:
1. Start, Control Panel,
2. Performance and Maintenance,
3. Administrative Tools,
4. Computer Management,
5. Disk Management,
6. Find the USB drive (usually the last storage device before the optical drive),
7. Click on the USB drive,
8. Right click on it and you will see the options (New Partition or Format)
9. Follow the instruction (I chose FAT32), but please do NOT chose Quick Format.
SanDisk Sansa... | Answered on Sep 20, 2016
Same problem with my sansa fuze 8 gig It skips over songs instead of playing them.
SanDisk Sansa... | Answered on Sep 10, 2016
The JPEG's that won't display are probably too high a resolution or the file size of the image may be too high. If you are using sandisk Sansa for instance you can use the Sansa Media Converter to change (lower) the resolution of the images, or you can use other software to alter the images.
SanDisk Sansa... | Answered on Dec 28, 2014
Hold the on/off slider for 30-40 seconds and then release to reset the device. Then try turning it on. Also, sometimes if the battery is low/dead it will take longer than 3 hours to charge up. If it does not turn on after the reset you might try letting it charge for a day or so and try again. If it doesn't work after all of this, it should be returned to where ever you bought it for a replacement.
SanDisk Sansa... | Answered on Aug 13, 2014
SanDisk Sansa Fuze MP3 Player Logo
1,067 questions posted
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
Sansa SanDisk
  • Sansa SanDisk
Most Popular Question
sandisk sansa fuze charge anymore
  • Audio Players & Recorders
