20 Most Recent
Brother HL 2140 Laser Printer Questions & Answers
How to turn off a
Sure a power switch shut off will not hurt anything but save you on eletric bills. Shoot you could even pull the plug and still get away with nothing happening but if you do not plug it back in then you know what happends then? You just dont print. So sure power button will put you in some great ECOLogistics thats for sure.
Thanks for the question, please do feel free to leave some postive feedback to keep these questions being anwered free.
Regards,
rulds2008 Btw, I’m available to help over the phone in case u need at
https://www.6ya.com/expert/edwy_1a56970cf1ea4620
I have brother Printer HL
hello
printer becomes offline if it is turn off or the pc not recognized the printer.
solution: check the cable printer, transfer cable printer port to another port in your computer, if the problem still occurs re-install the printer driver.
thank you
Corona wire AND MORE SPAM 1-800-975-0148
I was getting the clean the corona wire problem message even after repeated cleanings. Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated. So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner. I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again. The printer now works fine.
Brother 2140 Printer Problem
It is most likly not linked to word. Word is likly sending the prints to the wrong, obsloete or wrong copy of the printer.
When printing check to see where the doc is being sent to print.
Then go to printers to see which printer is your 2140 active and ofcourse do a test print. If the test print is good this is the correct link to your printer.
I recently installed the Brother
Set your new HL-2140 as the default printer. Go to Control Panel, Click Printers and Scanners tab, and set your Brother HL-2140 as your default printer. You may have other printer as the default printer currently. Check your connections again. Connect it to another USB port as the current port might not be responding due to connection contact problem.
I plugged it into 220V outlet and Brother HL 2140
hi. I had the same problem and to fix it you need to take printers right-side cover off. Underneath you'll find a Power Supply Board - hidden under metal cover. Take it out and disconnect two cables from it. Now, I had to replace an fuse 125V 4A and varistor E241AD 83P on the Power Supply Board in mine HL-2140. It works fine now.
Note: I could not find the exact replacements in electronic store so I used:
- fuse: 250V 4A
- varistor: FNR 10K241 (241 is the important number)
Hope it helps.
My machine is a Brother HL-2140 laser printer and
Please try to remove the program for a brother and then desconnect the cable, Turn on the printer and try enter in menu to print a test if that is working try to connect the cable in the printer and add the program of the brother in your computer.
Printer is on but will not print.
Hello ,
First, please make sure there is no error message displayed on the LCD screen of the printer
Now we will check the status of your printer in the printers menu in the control panel.
The printer’s status should be set to “ready”
If the printer is “paused” simply clear the print queue, right click on the printer and select “resume printing”.
If the printer says “offline”, follow these steps.
- Clear the printer queue
- Shut down the computer
- Unplug the USB cable from your computer and your printer
- Unplug the power cable from the printer and wait 15 seconds
- Plug the USB cable back into the printer and the computer.
- Plug the printer’s power cable back in.
- Turn your computer back on.
Your printer status should be back to ready now and you are able to print.
Thanks,
Pat
How or what needs to be cleaned, to remove an equal distant mark on center of the page every 76mm (3 inches).
Remove the drum unit and toner from the printer. Separate the toner from the drum. Look at the surface of the drum, rotating using the drive sprocket at one end. Look for a mark or foreign material on the surface of the drum in the same position as it is on the printed page. If you find anything, use a clean, dry kleenex tissue folded into a pad to carefully remove the mark and clean the drum. The 3 inches corresponds to the distance around the drum as it rolls down the page. If the mark cannot be removed, the drum should be replaced, it is a consumable that wears out in any case.
What does it mean when i get the error message
you need to turn it on, Go, . START>>RUN>>services.msc enter. When the services screen comes up, scroll down until you find the "Print Spooler" Enable it, Start it, and set to Automatic, reboot, ya good to go.
