Hi all how to solve the error code
SOURCE: Canon 405 Problem
when i start copy Error E100 occurs. How do i solve this problem please immediately send me the manual of canon 405 and immediately send me solution of this problem.
SOURCE: Copier ir 2016 system error E100
hi there
first replace the drum (i.e the photoconductive cylinder)
I wish you solve the problem.
thank you and not forget to vote me any how.
SOURCE: SYSTEM ERROR E100
1) Drum unit
Is the drum unit installed in host machine?
NO : Install the drum unit.
2) Connection
Is the connection of the connector (J908) on the BD detection
PCB, connector (J907) of the laser unit, and connector (J102) on
the DC controller PCB normal?
NO : Correct the connection.
3) Laser/scanner unit, DC controller PCB
Try replacing the laser/scanner unit. Is the fault corrected?
YES : End.
NO : Replace the DC controller PCB.
SOURCE: canon IR2020 photocopier
BD detection PCB failure
The BD detection PCB is faulty.
- Check the connector of the BD detection PCB.
- Replace the laser scanner unit.
- Replace the DC controller PCB
SOURCE: canon e100 system error - call for service
just enter service mode & reset ( CLEAR ALL )
Additional Function>>>28>>>>Additional Functions
Scroll through to find CLEAR Select all...
Rate me if it was helpfull....
