20 Most Recent
Canon IR1018J Black and White Copier Questions & Answers
SYSTEM ERROR E100 on canon IR1018
Main cause The laser driver/BD PCB is faulty (laser activation failure, BDdetection fault). The DC controller PCB is faulty. The imageprocessor PCB is faultly.or drum is faulty.
HELLO Sir,
How to fix error e019 in canon ir1018?
E019 means your waste tank is full. In iR1018/iR1020 series copier, waste tank is located at drum unit. First, remove the drum unit from the machine. Second, open the white plastic lid of the waste container. Third, drain the waste. Re-fit the plastic lid of the waste container and re-insert the drum.
I have a canon ir 1018j black and white photocopier that does not pick a paper nor photocopy
If the problem is simply that the machine is not feeding paper, you should clean the paper pick up and feed rollers. Typically there will be one attached or above the paper tray(s) and a couple that transfer the paper through the machine to the print drum and fuser. Find them and clean them with clean cloth wet with a dilute solution of dish wash detergent with a few drops of methylated spirit or isopropanol mixed in. If paer then feeds but no print - you have more serious issues.
How do i fix fix ''out of toner'' issues
Have you tried pulling out toner cartridge and shaking it? Does this fix it for a short period. Make sure you are purchasing a quality toner. Thank you so much. Leave feedback and let us know.
In the middle copy is coming white
Dear
It is due to the consumable problem check the following
1- check the drum life> if possible clean the PCR roller with isopropyle alcohol, clean the drum blade.
2- detach the developer assy. and turn the mag roller to check the even flowing of toner, if you are experience clen the doc. blade and roller bushes of the developer assy.
3- check the transfer roller and its contact points clean it with soft anti static brush.
Thanks.
Message says SYSTEM ERROR E100
This error is related with the laser unit. Disassemble that unit and clean the internal mirrows, if problem persist replace the laser unit
E19
E019 0000
Waste toner full detection
The waste toner full state was detected.
Firmware for canon iR 1018
you need a special service tool to load the firmware to the copier and usually only canon sevice technicians have access to it,
you may need to call a canon agent service centre
