20 Most Recent Konica Minolta bizhub C351 All-In-One Laser Printer Questions & Answers
Low power code fuser not warm up properly
Konica Minolta... | Answered on Apr 16, 2019
Code
B116
Description
Communication error with the fax board
An undefined communication error occurs between the controller and the fax board.
Remedy
1 Check the connector CN106 on MFPB for proper connection and correct as necessary.
2 Change FAXB.
3 Change MFPB.
That error means a problem with the FAX Board. Now, checking connections or re-seating connections of fax board to main board are advised first, then replacing fax board if that fails.
Konica Minolta... | Answered on May 15, 2018
Did you replace the main board if so the the small board on the main board does not match the info on the other board and you have a NV RAM error NVRAM stores the serial number counter info very important info. Need a tech to re-flash the firmware not drivers maybe a new board and NVRAM
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 25, 2018
replace the black image unit
Konica Minolta... | Answered on Mar 18, 2018
sorry there is no service code 5353 in the c350 your sure???
Konica Minolta... | Answered on Mar 10, 2018
Did you have the firmware (Copiers Operating system) NOT DRIVERS updated??????? Do this step
1. If it occurred after upgrading the Firmware,
conduct the following setting.
[Service Mode] ? [Sate Confirmation] ?
[Memory/HDD Adj.] ? [HDD Version Up]
If not do this:
2. Turn OFF the main power switch and turn it
ON again, and conduct the following setting.
[Service Mode] ? [System 1] ? [Initialization]
? [Data Clear].
IF not reformat the hard drive, or replace it.
Worse case replace the main board$$$$$$$$$$$$$$$$$$$$$$$$
replace the cyan image unit
you need to load the proper firmware. do you have a card that you can load the firmware onto? i can load the software on a card and send it to you if needed....
Konica Minolta... | Answered on Jan 30, 2018
this is a fusing pressure roller code.....
The way to clear the code is by opening/closing the front door.
Konica Minolta... | Answered on Jan 20, 2018
In Konica Minolta bizhub 210,162,211,163,182, error code "cof32" means "Automatic toner density control abnormality.
To remove this code or you want to get rid of this problem, simply call your technical service representative to solve this problem.
If you want to remove this code by yourself then please perform these actions attentively.
1-Turn the machine ON.
2-Press "Utility" button on front panel.
3-Now press these buttons "stop+0+0+stop+0+1" it means press stop button, then press 0,again 0, then again press stop button, then press 0, and 1.
4-service mode will appear on LCD screen.
5-Now with the help of arrow keys go to the 2nd option which is "ADJUST"
6-Now press "YES" button.
7-Again by pressing the down side arrow key go the option which is "ATDC ADJUST".
8-Press YES button.
9-Now increase the value, for example if the value is 145, you have to enter 155 or 160.enter the value with numerical key pad buttons.
10-After entering the new value press "YES" button.
11-Restart the machine.
Konica Minolta... | Answered on Jun 29, 2017
is this for the fax?? buy a fax kit
Konica Minolta... | Answered on May 05, 2017
Thermisters / Heat Sensors abnormality. Replace the thermisters, in order to get rid of this problem permanently.
Konica Minolta... | Answered on Nov 12, 2016
C-E002 - message and method parameter failure - possible MFPB fault
Konica Minolta... | Answered on Oct 15, 2016
replace the fuser
Konica Minolta... | Answered on Jul 09, 2016
replace the drum and developer
Konica Minolta... | Answered on Jul 04, 2016
which one
Konica Minolta... | Answered on Jun 30, 2016
which is it c35 or c351
Konica Minolta... | Answered on Jun 27, 2016
replace the hard drive
what error
Konica Minolta... | Answered on Jun 25, 2016
Konica Minolta bizhub C351 All-In-One Laser Printer Logo
305 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
bizhub c250 c e002 error
  • Office Equipment & Supplies
