20 Most Recent Konica Minolta bizhub 250 All-In-One Laser Printer Questions & Answers
try pull up error
Konica Minolta... | Answered on Apr 20, 2019
  1. Has the developer been replaced along with the drum They are normally replaced as one. If not that is why it is coding out.
Konica Minolta... | Answered on Apr 17, 2019
Are you getting any warning on the Screen? Such as Error Code or Replace the waste toner Box etc.
Konica Minolta... | Answered on Feb 02, 2019
my machine konica minolta C252 is giving the code 9401 how should I resolve and what is
Konica Minolta... | Answered on Nov 29, 2018
I think your problem comes from the scanner, try the operation if you have anotherPWB-C when you turn on the machine.
5/16/79 CC151: Error upon startup ROM contents (MSC)
5/16/80 CC152: Error upon startup ROM contents (Scanner)
5/16/81 CC153: Error upon startup ROM contents (PRT)
5/16/82 CC154: Error upon startup ROM contents (PH)
1 Check the ROM version. -
2 Rewrite the firmware. -
3 Replace the Appropriate board.
Konica Minolta... | Answered on Jun 08, 2018
Sir/Mam,
Turn off the main power switch, ensure the sub power switch is on. The sub power switch is located on the right side of the control panel. Then holding down the Utility/Counter button turn the main power switch on. Close the front door you must keep the Utility button down. The screen will show TROUBLE RESET touch it sees a "OK" then power off the machine. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back, you need a Fusing unit Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE! THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! A Fire could occur and that would ruin a perfectly good day!!!!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Konica Minolta... | Answered on Mar 25, 2018
select you tube and ask how to set ip address for konicaminolta di 2510
Konica Minolta... | Answered on Mar 18, 2018
reset code is 00000000 is default if the code come back replace the fuser unit the HOT PART keep reset can cause a fire that will ruin a perfectly good day!!!!
Konica Minolta... | Answered on Feb 25, 2018
When the copier is on the network does the little leds flash at the network connection? ping the ip address of the copier what do you get.
Go into admin mode on the copier network setting what is your ip address, subnet and gateway reading did you replace a router? now the network is one system and the copier was never told this new info?
how about the other computers? did that computer have its password changed?
Konica Minolta... | Answered on Feb 19, 2018
minumum size for the bypass is 3.5x5.5 and max is 11x17
minimum, for the paper trays is 5.75x8.25 and the max is11.5x16.5
so it should run 5.5x14 in the bypass tray
1 load the paper in the bypass tray
2 in the basics screen touch paper
3 select the button for the bypass tray
4 touch change setting
5 select custom size and program the size
Konica Minolta... | Answered on Feb 01, 2018
you might disconnect all power and reconnect to perform a power on reset. Then if the switch that detects the section is open or closed is working properly, then the circuit board that reads the switch is defective. Replace components as needed. the switch should be checked with a volt/ohm meter.
Konica Minolta... | Answered on Dec 23, 2017
If utiity is not working first of all clean with some alcohol and if this does not make it work you have to change the display or just enter web utility and make all changes it is the same only if you have installed as a printer in network
Konica Minolta... | Answered on Oct 10, 2017
I can even reach the "service mode".
The screen shows the error (c2557) and I can not access to anyother function.
Konica Minolta... | Answered on Aug 25, 2017
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Konica Minolta... | Answered on Jul 19, 2017
reset life of actual transfer
Konica Minolta... | Answered on Jun 22, 2017
Did you down load the print drivers from KonicaMinolta??? mite also be the firmware, have tech come out and update it. try this site
Self Help Product Support Konica Minolta Business Solutions Inc
Konica Minolta... | Answered on Jun 18, 2017
Replace the roller set for that draw and the associated clutch. Does this happen with the second draw also?
Konica Minolta... | Answered on Jun 11, 2017
Might have a KMBS tech come out and update the copiers Operating system (Firmware). Driver is for the computer firmware is for the copier which is located on a secure server KMBS wishes to protect its printing software
Konica Minolta... | Answered on May 06, 2017
Konica Minolta bizhub 250 All-In-One Laser Printer Logo
Popular Tags
519 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
George Mclaughlin
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
bizhub Konica Minolta
  • bizhub Konica Minolta
Most Popular Question
solve c2557 error
  • Office Equipment & Supplies
