When you only get 5 mbps are you connecting to the new router wirelessly or via the ethernet cable? If it is wirelessly then try connecting with an ethernet cable and see if you still get 5 mbps. If so then try resetting the router (the procedures for this will be explained in the manual) and re-test. Wireless connections can slow down due to obstacles such as thick walls or other obstacles of that type. If all else fails return the unit and try another.
