20 Most Recent Belkin N1 Vision Wireless-N Wireless Router with 4-Port Switch Questions & Answers
Setup cd
HERE ARE THE APP DOWNLOAD http://en-us-support.belkin.com/app/answers/detail/a_id/540/kw/N1
12/19/2011 1:53:28 PM • Belkin N1 Vision... • Answered on Dec 19, 2011
No I'dont find that I
Go to this link http://en-us-support.belkin.com/app/product/detail/p/327
and download the new firmware
8/15/2011 12:15:00 AM • Belkin N1 Vision... • Answered on Aug 15, 2011
The playstation 3 does not
Generally what happens is that progress will stall whilst you are trying to update the firmware or software/games on your PS3, causing it to be corrupted. Your console is then unable to function properly, and you are left trying to "pick up the pieces" as it were. The PS3 error 80710723 is one of these system update errors, and is often experienced by gamers who use wireless connections to update their firmware or games.
So how can you fix PS3 system update error? Here are a few steps you can take to try and fix the 80710723 error code yourself.
  1. In your System Options/Network Settings you need to go and disable a setting called "media server". Doing this has been reported to fix the PS3 system update error in a number of different cases.
  2. If you are using a wireless network connection then switch to a wired connection and attempt to update your console. Wireless connections can have interference, or fail from time to time. Therefore it is better to use a wired Internet connection where possible.
  3. As a last ditch resort you can actually download the update from the Sony website onto your PC, then load that update onto a USB stick and plug it into your PS3 and carry out the update process from there. However, it is best to actually try and fix your connection problems first.
1/8/2011 10:17:39 PM • Belkin N1 Vision... • Answered on Jan 08, 2011
On Modern Warfare 2 I have a STRICT N.A.T type.
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
10/20/2010 10:51:43 AM • Belkin N1 Vision... • Answered on Oct 20, 2010
Keep losing internet connection
Hi Dave,
I got your issue , You have mentioned that you are losing the internet connection through the router .
To fix this issue You need to update the firmware on the router . I have given you the link to download the firmware from the website
http://en-us-support.belkin.com/app/answers/detail/a_id/527/kw/8231/r_id/166
1.You have not mentioned the version number of the router , so please check the version number (in the bottom of the router)
For example: If its version 4000, then you have to download 4xxx firmware which is in the link.
2.After downloading the firmware from the website, save this file in a location where you can easily identify(eg: desktop)
3.connect the comp to the router with the ethernet cable to the router in any one of the wired slot and open the browser(eg: Internet explorer) and in the address bar type 192.168.2.1 and enter.
you will be logged into the router setup page.
4.Look on the left side of the page under Utilities , click on firmware update
5. then if its asking for login password, leave the password as blank and click on submit.
6. then click on browse and choose the file from the location where you save and then click update.
Once after firmware update you will not have any problem in loosing connection. please try this I'm sure it will work.
Thanks & Regards,
Prema
10/9/2010 12:53:49 PM • Belkin N1 Vision... • Answered on Oct 09, 2010
How to change NAT type on sierra wireless 595u aircard?
PS3 and Xbox ( NON BELKIN)
You Will Have to Disable the Firewall In Your modem / Router
And IF it is a router then Open The Ports
• TCP 80
• UDP 88
• UDP 3074
• TCP 3074
• UDP 53
• TCP 53
And also make sure that UPnP is Enabled
9/30/2010 11:53:04 AM • Belkin N1 Vision... • Answered on Sep 30, 2010
802.11n problem.
Please follow the mentioned step to check if the Wireless card is installed properly
Step 1 :
> click on start (assuming it to be a windows OS)
> right click on "my computer" and select "Properties"
> you will have the system Properties window pop-up
> under the Hardware tab, click on Device manager button
> under the device manager list look for network adapters
> you should now be able to see your wireless card under network adapter - check if the adapter is enabled ( if not kindly enable by right clicking on the adapter)
> once the adapter is active - it will have a green icon with not error on it.
> Now try to search for the network again - this should work..
5/11/2010 11:51:52 AM • Belkin N1 Vision... • Answered on May 11, 2010
I have lost the quick installation guide for this
http://www.belkin.com/support/article/?lid=en&pid=F5D8232-4&aid=10177&scid=0
5/2/2010 7:41:01 AM • Belkin N1 Vision... • Answered on May 02, 2010
2answers
Belkin n1 vision F5D8232-4
after upload the frimware its goes to default setting then you have to re-configure it sir
9/26/2009 10:20:59 PM • Belkin N1 Vision... • Answered on Sep 26, 2009
0answers
How to change time and date on a screen?
Push the right key (>) or the left key (<) to cycle
through the display modes.
Pages 18-21 of the user manual
3/3/2009 1:11:50 AM • Belkin N1 Vision... • Answered on Mar 03, 2009
Nat type
Try this link this shows how to forward ports on your belkin router.
2/13/2009 7:16:01 PM • Belkin N1 Vision... • Answered on Feb 13, 2009
Belkin F7D4301 is unavailable in browser
Visit Belkin Official Support - F7D4301 Downloads There are two versions of firmware available. Version 4 and Version 1. To downgrade your router firmware, use version 1 firmware. I hope this will resolve your issue.
9/14/2023 1:27:46 PM • Belkin Computers... • Answered on Sep 14, 2023
Mtv music generator detecting directx 7
ok... so I've now installed this on my new pc that i built... first in order to get it to install at all you must download DirectX 7.0 and right click to "--(edit compatibility settings to windows 98/Me and run as administrator)--" remember this as well be doing it a few times. once you do that install DirectX 7.0 and say yes to all. now that this is installed take the .iso file you have and burn it to a cd or DVD-r, once burned you need to go to my computer and right click on the cd/DVD drive, select open (NOT open autoplay), inside the disc menu i want you to go to 2 files... "setup" and "start" need to also have their compatibility settings changed to the above settings. now that these are set stay in the cd menu and double click "setup" this will take you through the setup procedure. after the setup procedure is finished do not view the notes, and continue back to the desktop. now from your start menu load the game and it should run
3/19/2023 8:35:19 PM • Belkin Computers... • Answered on Mar 19, 2023
I cannot connect to the
you need more than a wireless adapter to connect to the internet......
you need a wireless network to connect to. in cafe's and pubs the owner sometimes sets up a WiFi network that their patrons can connect to, however most people have to provide their own.
to get to the internet , you will need.
A broadband connection (ADSL / Cable) this normally comes with a standard NON wifi modem
A WiFi Router (including ADSL / Cable Modem) depending on what you have already.
then to link a remote PC / Laptop to this network, A suitable wireless adapter ( like your belkin adapter)
it is a common misconception that a wireless adapter is all you need (advertising is vague)
7/20/2022 6:29:10 AM • Belkin Computers... • Answered on Jul 20, 2022
Blue light flashing
Do a hard reset,usually there is a button on the back of the router.With power plugged in,press and hold reset button 15 sec. then without releasing button remove power plug and hold an additional 15 sec.,then plug power cord back in and hold an additional 15 sec. After that release the reset button and it should reset to default.You may need to do this a few times but it should solve your issue.
7/20/2022 6:21:33 AM • Belkin Computers... • Answered on Jul 20, 2022
3answers
How do I Reset my Belkin wifi Extender?
Using the reset button The location of your range extender's reset button will vary depending on its model. The reset begins once you press and hold thereset button for at least 10 seconds while the range extender is powered ON. The Status Light on the the range extender will momentarily flash and will then begin to blink. When the light becomes solid again, the reset is complete. Using the web-based setup page If using the physical button does not work, you can access the range extender's web-based setup page and do the reset from there. Before you begin:
  • Make sure that the wireless computer or device you're using to access the web-based setup page is connected to the same network as the range extender.
  • You need to identify the IP address that your router has assigned to your range extender. Locate this by accessing your router's DHCP Client table. Once you have the range extender's assigned IP address, use it to access your range extender's web-based setup page.
  • Alternatively, you can enter "http://192.168.206.1" in the web browser's Address bar if your range extender has NOT detected a DHCP server in your network.
Step 1: In the web-based setup page of the range extender, go to Utilities and select Restore Factory Defaults. QUICK TIP: You may be prompted to log in with your range extender's administrator password. If you have not set any, simply leave the field blank and click on Submit. Step 2: Click on the Restore Factory Defaults button. Your Belkin range extender should now be restored to its factory default settings.
1/19/2022 12:25:42 PM • Belkin Computers... • Answered on Jan 19, 2022
Drivermax
Routers are very important for setting up an internet connection. As we all know, the Internet is the most important network, which connects us to the world. There are various companies exist in the market, which offers routers. But Belkin is the top market-leading company for routers. Advance features, technology is the attributes of the Belkin router. For a new router user, installation is a big challenge, and in case the user doesn't.have installation CD then it becomes more difficult. So in this blog, we are going to discussHow to Setup Belkin Router Without CD. Now, you do not need to worry about the installation process, There are 2-3 ways to set up Belkin Router Without a CD.Now one question comes to your mind, How? So Tech Support Experts are here to answer all your queries. Our team is experts in technology and here we will elaborate on the steps to Setup Belkin Router Without CD.
8/11/2021 9:42:08 AM • Belkin Computers... • Answered on Aug 11, 2021
How to uninstall belkin security
Scroll down and select your Belkin device's setup utility. This varies by product, but begins with "Belkin" followed by your device type. Click "Uninstall" and enter your Windows administrator password if prompted. Click "OK" to confirm that you wish to uninstall.
How to Uninstall a Belkin Utility
6/10/2021 8:19:04 AM • Belkin Computers... • Answered on Jun 10, 2021
Belkin N1 Vision Wireless-N Wireless Router with 4-Port Switch Logo
Popular Tags
19 questions posted
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
no 39 dont find
  • Computers & Internet
