20 Most Recent
Belkin 802.11g Wireless Notebook Network Card [ F5D7010 Wireless ] (109062) Questions & Answers
I have a high speed
have you checked your firewall permissions and the antivirus permission allows
I have a belkin 802.11g
This message generally means that you are attempting to connect to a password (secure) network. You have to reestablish the connection by inputting the password before full connectivity can be achieved.
Let's assume you are using XP. Troubleshooting this problem is described at
http://support.microsoft.com/kb/892896
Let me know if you need more information. Thanks.
I have a Belkin Wireless Notebook Network Card
YES. There are some PCMCIA readers that connect to your PC/Laptop USB. Here is one on eBay:
http://cgi.ebay.com/Elan-Digital-System-USB-Card-Reader-PCMCIA-to-USB_W0QQitemZ250412518018QQihZ015QQcategoryZ14981QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Mtv music generator detecting directx 7
ok... so I've now installed this on my new pc that i built... first in order to get it to install at all you must download DirectX 7.0 and right click to "--(edit compatibility settings to windows 98/Me and run as administrator)--" remember this as well be doing it a few times. once you do that install DirectX 7.0 and say yes to all. now that this is installed take the .iso file you have and burn it to a cd or DVD-r, once burned you need to go to my computer and right click on the cd/DVD drive, select open (NOT open autoplay), inside the disc menu i want you to go to 2 files... "setup" and "start" need to also have their compatibility settings changed to the above settings. now that these are set stay in the cd menu and double click "setup" this will take you through the setup procedure. after the setup procedure is finished do not view the notes, and continue back to the desktop. now from your start menu load the game and it should run
I cannot connect to the
you need more than a wireless adapter to connect to the internet......
you need a wireless network to connect to. in cafe's and pubs the owner sometimes sets up a WiFi network that their patrons can connect to, however most people have to provide their own.
to get to the internet , you will need.
A broadband connection (ADSL / Cable) this normally comes with a standard NON wifi modem
A WiFi Router (including ADSL / Cable Modem) depending on what you have already.
then to link a remote PC / Laptop to this network, A suitable wireless adapter ( like your belkin adapter)
it is a common misconception that a wireless adapter is all you need (advertising is vague)
Blue light flashing
Do a hard reset,usually there is a button on the back of the router.With power plugged in,press and hold reset button 15 sec. then without releasing button remove power plug and hold an additional 15 sec.,then plug power cord back in and hold an additional 15 sec. After that release the reset button and it should reset to default.You may need to do this a few times but it should solve your issue.
