20 Most Recent Belkin N1 Vision Router Questions & Answers
Is the Belkin plugged into a power strip or UPS? Try another AC outlet. Has the AC jack,plug in the rear or the Belkin been damaged due to pulling on the AC cord, causing a lose connection? Is your computer shut down at night? No Hibernate, No Sleep? Are their setting for the Belkin to shut down/timeout after a certain idle time? Here's a user manual: http://cache-www.belkin.com/support/dl/f5d8632-4_usermanual.pdf
Belkin N1 Vision... | Answered on Feb 14, 2013
Open a command prompt. Start, Run, type cmd <enter>
If the drive you want to format is F: for example type
format F: /FS:FAT32
Belkin N1 Vision... | Answered on Nov 27, 2012
You will need to log into your router with the IP Address, userid and password, then you can change the router password.
You do realize that the Router Password just lets you get into the router to make changes to it.
The Wireless Password is what allows people to connect their wireless devices or laptops to the internet via the router. If you need to change the wireless password then once you get into the router go to the wireless tab or wireless security and change it.
The manual will give you the router's IP address, default userid and password. Also it might be on a sticker on the side or bottom of the router. The wireless password or network key might be on it also.
If you need the manual go to Belkin's website.
Get online and got to www.google.com In the google search box type: "Belkin Support" (without the quotes and put your manufacturer name before Support). Look for downloads and drivers. Enter your model number and operating system when requested. Look for Manuals throughout the site.
Below is a direct link to their site where you just plug in your model number.
http://en-us-support.belkin.com/app/product/list/q/routers/
Belkin N1 Vision... | Answered on Jun 05, 2012
PS3 And XBOX :: BELKIN
Step 1:Connect Modem - Router - Computer (Wired)
Step 2:Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3:On the Left click firewall
Step 4:Leave the Password blank and click submit
Step 5:Disable it and click apply changes
Step 6:Scan and connect in the Xbox/PS3/Wii
Step 7: Get the IP Address of the Xbox/PS3/Wii
Step 8:Open Router Setup in the Computer
Step 9:On the left under Firewall Click DMZ
Step 10:Enable the IP Address of the Xbox/PS3/Wii in it
Step 11:Click Apply Changes
Step 13:On the left Under Utilities click System settings
Step 14:Scroll down to the bottom
Step 15:Enable UPnP
Step 16:Click apply changes
Step 17:Test the connection ,Check the NAT
If working then let me know
If it is still not working
Open Router setup
At the middle Under internet settings check the WAN IP
IF it starts with 192.168. or 172.16 Then you will have to contact your internet service and ask them to bridge the modem
Regards
TOM
Belkin N1 Vision... | Answered on Apr 18, 2011
should be able to work with a cable or wirelessly.
Belkin N1 Vision... | Answered on Mar 06, 2011
Yes, all the setting and password, WEP encryption password, etc WILL BE LOST. Well they are not actually lost, they remain on the old router until you delete them or reset the router to the factory default.
I think what you are really looking for is will the setting and passwords transfer automatically(NO)
So you need to write down the old setting and password if you want to keep them and put them into the new router during set-up.
Unless you are going to personally keep the old router, for security, reset it to clear out the passwords.The reset procedures is the same for both routers
Just in case you do not have the new owners manual here is the direct link to Belkins.
http://cache-www.belkin.com/support/dl/p75490_f5d8232-4_man.pdf
j
I answer these questions for free : a 4 THUMBS rating and POSITIVE Comment is really appreciated for the FREE answering of your question.
Capt. Spock said: "An ancestor of mine maintained, that if you eliminate the impossible, whatever remains, however improbable, must be the truth."
Belkin N1 Vision... | Answered on Mar 03, 2011
I hade the same problem with mv Cisco VPN v5.0 and Belkin N1 router (F5D8231-4 v4...). I could only solve the problem with a new firmware (f5d8231-4 ww v4.00.18 at http://www.belkin.com/uk/support/article/?lid=enu&pid=F5D8231uk4&aid=9419&scid=0 ). I think this is a general firmware issue at Belkin. Good luck.
Belkin N1 Vision... | Answered on Jan 13, 2011
This is because your router is dropping the connection with your ISP Modem...
It can be even an issue of modem...
To isolate the issue, what you can do is... You can connect your computer directly to the Modem and you can check for any intermittant connectivity...
if you dont have any problem with your modem, then definitely its gonna be the problem with your Belkin Router...
Doing a reset for the router and reconfiguring will resolve the issue in most of the cases...
If in case if it doesnt works, then you can do a firmware update for the router (that would be found in belkin router support website)...
Even then if it is dropping the connection then definitely it is a faulty router...You can ask for a replacement if the product is still under hardware & software warranty...
i work for belkin...
you can reach us any time in 1800-223-5546 if u are calling from USA...
we work 24 X 7....
For any other countries search in www.belkin.com/support
Belkin N1 Vision... | Answered on Dec 09, 2010
Hi .....
I got your issue .....
Try with the following steps ....
Step 1: Connect modem>>router>>computer
Step 2: Opened the internet explorer
Step 3: On the address bar type http://192.168.2.1
Step 4: you will get a router page
Step 5: Towards the left column below wireless click on channel and ssid
Step 6: Change the channel to 11 and then click on apply changes
Step 7: Then close the screen and check with the connection
If you have any issues contact the toll free belkin technical support 1802235546
Thanks .....
With regards....
Priya
Belkin N1 Vision... | Answered on Oct 20, 2010
1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox)
2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window)
3.Note router name you are connecting to.
4.. Check the laptop do ipconfig /all to see current IP addresses.
5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser.
6.Note router name you are connecting to.
7. Move the laptop about 20ft away and try to log on to the internet.
This is for all routers to set up wirelessly.
8. check for firmware update at the manufacturers site for your model router
9. cell phones, cordless phones, digital TV's, can affect the data signal from a router. Also distance from the router can be a factor. If your router is in a basement place the router to a upper floor and center it in the room.
Belkin N1 Vision... | Answered on Sep 08, 2010
<span id="ctl00_ctl00_MainColumn_CenterColumn_ThreadSolutions1_Repeater1_ctl00_lblSolution"><span>1.Look at the back of the router and connect your laptop to any one of the 4 grey slots <br />2.In your laptop open IE and in address bar type <span style="font-weight: bold;">192.168.2.1</span><br />3.It will open a belkin router setup <br />4.In the belkin Router page select <span style="font-weight: bold;">SECURITY</span> in the left hand side <br />5.It will ask u a <span style="font-weight: bold;">login Pwd</span> . its <span style="font-weight: bold;">blank</span> Click <span style="font-weight: bold;">submit </span><br />6.In the next page u can see the Security Mode - If it is WEP - KEY 1 will be your PWD<br />7.If the PWD is WPA . The Pre shared key or password PSK will be the PWD . <span>Uncheck Obscure PSK to view the PWD .</span></span></span>
Belkin N1 Vision... | Answered on Aug 26, 2010
one solution for all your questions...
cheers...
click here...
click here for all my tips....
Belkin N1 Vision... | Answered on Aug 22, 2010
Belkin N1 Vision Router Logo
83 questions posted
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Jeffrey Groves
Jeffrey Groves
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
currently belkin wireless g mimo want
  • Computers & Internet
