20 Most Recent Belkin USB PDA Adapter (F5U109EA) Serial Adapter Questions & Answers
4answers
Is there a Windows 7 driver for the Belkin F5U109 BEWARE SPAM NUMBER +1-800-532-4187 BELOW
Sure there is. This amazing tool driverupdate us will keep every single driver up to date like no other program (from personal experience). Take a look and enjoy
2/9/2021 1:18:38 PM • Belkin USB PDA... • Answered on Feb 09, 2021
0answers
0answers
Need a driver for Windows
No, this product is not compatible with Windows 7 - 64 bit. It is compatible with Vista 32 bit computers. however u have a similar adapter which is compatible with Vista 64 bit, and Windows 7 - 64 bit you can use part F5U257 (USB-to-Serial Adapter).
8/15/2011 12:25:23 PM • Belkin USB PDA... • Answered on Aug 15, 2011
Windows 7 not compitable with
can you confirm if it is F5U409?
If so the solution would be to install windows vista drivers. in belkin site it says that windows 32bit are compatible with the adapter.
http://en-us-support.belkin.com/app/answers/detail/a_id/590/~/is-the-f5u409-usb-pda-adapter-compatible-with-vista-64-bit%3F
5/10/2011 6:22:22 PM • Belkin USB PDA... • Answered on May 10, 2011
My Belkin USB PDA Adapter Serial adapter when
In my effort to find answer I created a bigger issue. Answer to my Belkin issue was found at the Belkin website. But now due to my own failure to read all the details of acceptance of what I thought was what was necessary to get help; I am into another software 'pay-me' software program costing $10/month or $12+ for one time help of something which is simple to fix (Fix-ya). I got tired of paying Microsoft $25 each time to answer a simple question and often told to re-booth my entire system at 'possibe loss of my info'. When I found the answer and told them what I did to fix my pervious problem they did not credit me or pay me $25. And now there is Fix-ya; NO THANKS. Please remove me from your support group list. Not interested. JB
2/17/2010 2:33:36 PM • Belkin USB PDA... • Answered on Feb 17, 2010
3answers
Belkin f5u409 driver
Found a driver at www.driverguide.com Register with the site, search for f5u409 and the third one down I think is the Vista driver. Hopefully should solve your problem.
11/4/2008 9:30:10 PM • Belkin USB PDA... • Answered on Nov 04, 2008
3answers
I have a Belkin 1GB
A: if you want to take a risk, try bending the top of it back to it's normal position.
B: You might want to open it up and check for internal damage. Most flash drives are held together by a screw or can be **** open with a penknife. Bend the plug back to it's normal position, and try putting it back in your computer. If your computer picks it up, copy off all the data, and buy a new flash drive!
If that doesn't work, contact a data recovery specialist in your area, and they will be able to help you! Good Luck!
8/7/2008 10:22:00 AM • Belkin USB PDA... • Answered on Aug 07, 2008
USB/Serial Adapter (F5U109)
I had the same problem. I went to my Device Manager and checked the port setting for my cable. I reset the port in advanced properties and I was then able to do a transfer. I still have a yellow flag on my cable and get the error 10 but for some reason it did the transfer???
3/2/2008 4:02:20 AM • Belkin USB PDA... • Answered on Mar 02, 2008
Belkin F7D4301 is unavailable in browser
Visit Belkin Official Support - F7D4301 Downloads There are two versions of firmware available. Version 4 and Version 1. To downgrade your router firmware, use version 1 firmware. I hope this will resolve your issue.
9/14/2023 1:27:46 PM • Belkin Computers... • Answered on Sep 14, 2023
Mtv music generator detecting directx 7
ok... so I've now installed this on my new pc that i built... first in order to get it to install at all you must download DirectX 7.0 and right click to "--(edit compatibility settings to windows 98/Me and run as administrator)--" remember this as well be doing it a few times. once you do that install DirectX 7.0 and say yes to all. now that this is installed take the .iso file you have and burn it to a cd or DVD-r, once burned you need to go to my computer and right click on the cd/DVD drive, select open (NOT open autoplay), inside the disc menu i want you to go to 2 files... "setup" and "start" need to also have their compatibility settings changed to the above settings. now that these are set stay in the cd menu and double click "setup" this will take you through the setup procedure. after the setup procedure is finished do not view the notes, and continue back to the desktop. now from your start menu load the game and it should run
3/19/2023 8:35:19 PM • Belkin Computers... • Answered on Mar 19, 2023
I cannot connect to the
you need more than a wireless adapter to connect to the internet......
you need a wireless network to connect to. in cafe's and pubs the owner sometimes sets up a WiFi network that their patrons can connect to, however most people have to provide their own.
to get to the internet , you will need.
A broadband connection (ADSL / Cable) this normally comes with a standard NON wifi modem
A WiFi Router (including ADSL / Cable Modem) depending on what you have already.
then to link a remote PC / Laptop to this network, A suitable wireless adapter ( like your belkin adapter)
it is a common misconception that a wireless adapter is all you need (advertising is vague)
7/20/2022 6:29:10 AM • Belkin Computers... • Answered on Jul 20, 2022
Blue light flashing
Do a hard reset,usually there is a button on the back of the router.With power plugged in,press and hold reset button 15 sec. then without releasing button remove power plug and hold an additional 15 sec.,then plug power cord back in and hold an additional 15 sec. After that release the reset button and it should reset to default.You may need to do this a few times but it should solve your issue.
7/20/2022 6:21:33 AM • Belkin Computers... • Answered on Jul 20, 2022
3answers
How do I Reset my Belkin wifi Extender?
Using the reset button The location of your range extender's reset button will vary depending on its model. The reset begins once you press and hold thereset button for at least 10 seconds while the range extender is powered ON. The Status Light on the the range extender will momentarily flash and will then begin to blink. When the light becomes solid again, the reset is complete. Using the web-based setup page If using the physical button does not work, you can access the range extender's web-based setup page and do the reset from there. Before you begin:
  • Make sure that the wireless computer or device you're using to access the web-based setup page is connected to the same network as the range extender.
  • You need to identify the IP address that your router has assigned to your range extender. Locate this by accessing your router's DHCP Client table. Once you have the range extender's assigned IP address, use it to access your range extender's web-based setup page.
  • Alternatively, you can enter "http://192.168.206.1" in the web browser's Address bar if your range extender has NOT detected a DHCP server in your network.
Step 1: In the web-based setup page of the range extender, go to Utilities and select Restore Factory Defaults. QUICK TIP: You may be prompted to log in with your range extender's administrator password. If you have not set any, simply leave the field blank and click on Submit. Step 2: Click on the Restore Factory Defaults button. Your Belkin range extender should now be restored to its factory default settings.
1/19/2022 12:25:42 PM • Belkin Computers... • Answered on Jan 19, 2022
Drivermax
Routers are very important for setting up an internet connection. As we all know, the Internet is the most important network, which connects us to the world. There are various companies exist in the market, which offers routers. But Belkin is the top market-leading company for routers. Advance features, technology is the attributes of the Belkin router. For a new router user, installation is a big challenge, and in case the user doesn't.have installation CD then it becomes more difficult. So in this blog, we are going to discussHow to Setup Belkin Router Without CD. Now, you do not need to worry about the installation process, There are 2-3 ways to set up Belkin Router Without a CD.Now one question comes to your mind, How? So Tech Support Experts are here to answer all your queries. Our team is experts in technology and here we will elaborate on the steps to Setup Belkin Router Without CD.
8/11/2021 9:42:08 AM • Belkin Computers... • Answered on Aug 11, 2021
How to uninstall belkin security
Scroll down and select your Belkin device's setup utility. This varies by product, but begins with "Belkin" followed by your device type. Click "Uninstall" and enter your Windows administrator password if prompted. Click "OK" to confirm that you wish to uninstall.
How to Uninstall a Belkin Utility
6/10/2021 8:19:04 AM • Belkin Computers... • Answered on Jun 10, 2021
3answers
The modem light wont stop flashing amber
Replace it , they dont last long and often chips go inside them,cheaper to have replaced than repaired.
6/9/2021 8:15:30 AM • Belkin Computers... • Answered on Jun 09, 2021
Belkin USB PDA Adapter (F5U109EA) Serial Adapter Logo
16 questions posted
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
windows 7 driver belkin f5u109
  • Computers & Internet
