This is a common problem and easy to fix. Your temp sensor screws into the front side of the water manifold. You will just get a new one and swap it out. Your book will show you just where it is, but it's the size of a 1/2" plug on the top front of the manifold when you take the cover off the heater. Good luck.
Testimonial: "thank-you!"
Here is copy of the user's manual for these pool heaters. You will have it just in case any other issues arise.
http://www.backyardcitypools.com/images/bwp/Max-E-Therm-Manual.pdf
